coilover deals??
Discussion in 'The Hokey Ass Message Board' started by captmullette, Sep 20, 2010.
  1. captmullette
    captmullette
    need a set of rear coilovers the way it sits now i think i need a set 15 in. under load, about 250 lb springs...... i have the hamb faith, i know you guys will come through....:rolleyes:
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    There's a want ad section here..
    checkit out in the cl***ified section.
    I've had pretty good luck there
  3. djust
    djust
    from Oklahoma
    Pete and Jakes !
  4. The best price I've found is TCI All Americans. The best coilover, QA1s. but pretty pricey. Check the cl***ifieds here. I've got TCIs on my Roadster and I like them. 225lb, 14 inch, car is about 2300 lbs.
  5. captmullette
    captmullette
    thanks again hamb'ers , lot of time saved and good onfo.........., by the way, the man that bought the running chopped up mess, good luck, i know wht u are going thru. the only thing i used on my rolling ch***is, is the body...........
  6. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    Pro shocks, in Georiga they will custom make shocks for you.
  7. movingviolation
    movingviolation
    To be honest, i'm lov'n the cl***ifieds...i scored a new set of coilovers (tci) chrome with chrome springs (250lb) for $150!! I have been waiting out the cl***ifieds and buying stuff i know i will need.
    The HAMB offers it all.... friendship, advice and a great cl***ified section.
  8. That seems like a real heavy duty spring to me for such a light car.
    I don't think your going to like the ride too much.
    Anyone else care to offer their opinion?
  9. violet springs
    violet springs
    I would think 125 to 150 lb. springs, would work good on the rear of a car that weighs around 3000 lbs.
  10. i have 220 lb Pete & Jakes Viper Viper coil overs at a 27 degree angle at ride height on my `28 tudor full fendered sedan and they seam to ride and handle just fine for the last 15 years.
    your experience may differ
  11. captmullette
    captmullette
    im printing all this , ireally appreciate the help , im lost down here in the n. florida panhandle, not many hotrodders around here,, thanks again guys............
  12. captmullette
    captmullette
    found this ad in street rodder, lindblad ch***is,, 508-234-8283, coilovers were $ 105.00 a peice adjustable, look to be good quality, any spring rate, they even made me some extensions because i needed longer shocks.....
  13. 36-3window the greater the angle the stiffer the springs I've always had good luck with Pro Shocks, Lindbland ch***is has been around for a long time must mean something.
  14. Weasel
    Weasel
    Sometimes you'd be amazed how heavy a spring you need. My 1933 Willys sedan which weighs well under 3000 lbs is an example. With a 30˚ shock angle, started out with a 250 lb spring, went up to 300 lbs and then yikes 400 lbs. Finally ended up using 525 lb spring and now it rides fine, is not stiff, doesn't bounce and handles decently. Before it was a slushy, scary, rolly frightmare. I finally got it right when I talked to the tech guy at QA1/Carrera. This is not a guessing game but a science. I suggest you do the same to avoid wasting time and money and end up with a collection of springs like I did.
  15. violet springs
    violet springs
    <TABLE cl***=tborder id=post5536079 cellSpacing=0 cellPadding=6 width="100%" align=center border=0><TBODY><TR vAlign=top><TD cl***=alt1 id=td_post_5536079 style="BORDER-RIGHT: #e5e5e5 1px solid">To calculate the proper coil spring rate for the rear of your car, here is the imformation that you will need.
    weight on the rear tires
    weight of rear axle and tires
    distance the instant center (rear axle pivet point) is from the axle centerline
    distance the coil spring mount is from the axle centerline
    # of inches of usable shock travel
    example:
    weight of car at the rear tires 1277 lbs,
    weight of rear axle and tires 300lbs.
    the instant center measured 46.7" in front of axle centerline
    the coil spring measured 7" behind the axle centerline
    the shocks have 3" of useable travel
    take the weight on the rear tires 1277lbs. and subtract the weight of the rear axle and tires 300lbs.
    1277
    -300
    977 lbs.
    divide 977 by the number of springs (2)
    977 / 2 = 488.5 lbs.
    divide 488.5 by number of inches of useable travel (3) plus 1"
    488.5 / 4 = 122 lbs
    multiply 122 lbs by leverage ratio
    to calculate the leverage ratio you need to divide instant center distance 46.7. by total length of the instant center distance plus coil spring distance 46,7 plus 7
    46.7 / (46.7 + 7) = 0.87
    122 lbs / 0.87 = 106 lb. springs
    106 lb. spring ratio
    *this formula works for cars with the coil springs mounted vertical 90 degrees and behind the rear axle, if the coils are on an angle there are more calculations that need to be made to figure the proper spring rate*
    <!-- / message --></TD></TR><TR><TD cl***=alt2 style="BORDER-RIGHT: #e5e5e5 1px solid; BORDER-TOP: #e5e5e5 0px solid; BORDER-LEFT: #e5e5e5 1px solid; BORDER-BOTTOM: #e5e5e5 1px solid">[​IMG] [​IMG] </TD><TD cl***=alt1 style="BORDER-RIGHT: #e5e5e5 1px solid; BORDER-TOP: #e5e5e5 0px solid; BORDER-LEFT: #e5e5e5 0px solid; BORDER-BOTTOM: #e5e5e5 1px solid" align=right><!-- controls -->[​IMG]</TD></TR></TBODY></TABLE>
  16. PBRmeASAP
    PBRmeASAP
    Does Lindblad ch***is have a web site? or an i just to stupid to find it?
  17. chop32
    chop32
    I ran a pair of the Lindblad coilovers when I first built my fenderless '32 Ford pickup in 1996. At their suggestion, I got the 200# springs.
    The truck rode fairly rough and everyone who followed me on the highway said the rear tires spent a lot of time off the ground.
    I looked into a set of All Americans after about a year and they suggested their 180# progressive rate springs. Ive had them for over 12 years and couldnt be happier.
    The Lindblads seemed like a nice piece and the problem was probably too stiff of a spring, So do your homework with regard to spring rates.
  18. nummie
    nummie
  19. captmullette
    captmullette
    they dont offer a web site in their ad, i just gave them a call, real nice and helpful folks, my shocks are great, everyone has to determine their spring rate......;)
  20. rramjet
    rramjet
    I had good luck with the charts many of the suppliers offer that's based on rear weight and shock angle. Got 250's for my 32 sedan high boy mounted at 75 degrees. Weighs 1600 in the rear. QA1 adjustable shocks. They leveled things out so well on corners I haven't installed the sway bar I got for it.
  21. brucer
    brucer
    from western ky
    i got a set of aldan eagles for $200 off ebay.
  22. 1971BB427
    1971BB427
    from Oregon
    I bought a pair of used Konis off a Jaguar for $50. Check the local wrecking yards for a pair cheap!
