Technical Coilover question
Discussion in 'Traditional Hot Rods' started by MGK, Jul 24, 2017.
  1. MGK
    MGK
    from Ohio
    Replacing coilovers on a 29 Ford sedan. 200lb spring rate sound about right?
    Thanks. Chris
  2. bonzo-1
    bonzo-1
    Maybe.
    Need more info do you carry rear p***engers? Fenders? Mounted angle of shocks? What were the old ones? Use them over on the new ones. Shock length?
  3. MGK
    MGK
    from Ohio
    No rear p***engers
    Full fendered
    20 degrees
    No idea?
    14.5 fully open
  4. HOTRODPRIMER
    HOTRODPRIMER
    QA-1 adjustable 200lb rating. HRP
    Poh, Dino 64 and seadog like this.
  5. GordonC
    GordonC
  6. mgtstumpy
    mgtstumpy
  7. A model A rear spring will solve this in a hurry, My 29 with a 425 Buick Turbo 400 and Champ Q/C does just fine on an A spring?
  8. Schwanke Engines
    Schwanke Engines
    Go with the Carrera Coil overs from Speedway, they are made by QA1 and are very reasonably priced. I would go with 200-250 Depending on the Angle you end up mounting them at.
  9. moparjack44
    moparjack44
    I called QA1 tech, gave them total weight of car (4000 lbs) and my engine (392 Hemi). They recommended 250 rate. I ordered, installed, and completely satisfied. (NOTE, this for front only)
  10. swade41
    swade41
    from Buffalo,NY
    QA1 makes a great progressive rate spring it works great for my p/u and also my buddy's Anglia drag car.
  11. I put Afco coilovers on the rear of my highboy A Tudor, 250 lb springs, because it was to be full fender. I have the battery and 18 gallon fuel tank in the rear.
    In my opinion, my rear springs are a little to stiff. I probably need to be at 200 or 225 rating.
  12. hotrodmano
    hotrodmano
    from Norway
    Huh!!??. Whats a "Coilover" :rolleyes:
