Coils on a Model A what did u use?
Discussion in 'The Hokey Ass Message Board' started by lrs30, Mar 10, 2011.
  1. lrs30
    lrs30
    from Kentucky
    Anybody running coils on the rear of there model A and if so what ones/where/what:confused: from did you use and how do you like them?
  2. need louvers ?
    need louvers ?
    The old standard for coils used to be Corvair front coils. Still Fairly available if you look. Elpolacko and I were fooling around lately looking for a modern replacement and came up with Chrysler K-car rears... Haven't tried them yet, (will soon) but on paper they look like a good thing.
  3. lrs30
    lrs30
    from Kentucky
    Thanks for the info.. I am going to the yard tomorrow to see what I can scrounge up
  4. lrs30
    lrs30
    from Kentucky
    Anybody else?
  5. back in the late 70's when i built a `29 Ford pickup i used front coil springs from an early 70s Opel Manta on the rear. built pockets on the frame and rear end and had the shock up the center. worked great , but it may be hard to fine one in a junkyard
  6. fatboys69
    fatboys69
    from Tennessee
    I am using EIBACH coil overs that were "donated" from a buddy, the spring rate is 250lb ( whick is gonna be to stiff, but I will change ) .
  7. Casey J
    Casey J
    from Ada. MN
    I plan to run coils on mine as well. Check out brianangus's post How to build an early hotrod frame post #19 covers coils. If you are looking for pound values, I've herd 150lbs is what to shoot for.
  8. lrs30
    lrs30
    from Kentucky
    Cool I'd love to find a set of cheap coil overs...
  9. Checkerwagon
    Checkerwagon
    IRS30 , just a thought, motorcycle shocks / coils? I have no idea about lbs. or rates. Just thinking out loud. ?
  10. 33WIRE
    33WIRE
    I used Afo 5 inch diameter by 11 inches tall 150# sitting on top of the axle. On a 33 chev coupe they compressed to approx 8 inches.
  11. pitman
    pitman
    Corvair fronts worked well.
  12. need louvers ?
    need louvers ?
    Bingo! You can still buy them new too. They're not that expensive...
  13. arkiehotrods
    arkiehotrods
    In 70s, I ran corvair front coils on the back of my Model A coupe. Worked fine.
  14. gasserjohn
    gasserjohn
    speedway has kit /weld on cups ect......
    photo front coils done in 65
  15. mcknight05
    mcknight05
    from Ontario
    Ive heared some one say dodge neon before. but never the seen coils in person. the wrecking yard should be full of those
  16. 4ever18
    4ever18
    Here are a few photos of my old '30 Model A hiboy coupe, on which I installed Corvair front coils for my rear suspension. I liked them, fine. It's possible that the current owner is a HAMB member. The car was sold to someone in the Northeast by Randy Moore (Kingsport, TN). When the car was sold, it's tires & wheels were red steel wheels, full wheel covers, and white wall tires. I'm the guy that built the car and sold it to Randy. Last I heard, it was painted yellow and the new owner had chopped the top.
  17. hrm2k
    hrm2k
    I changed the rear suspension from air bag to coil spring. The springs are from a 1976 Mercury Capri 4 cyclinder front end. They have had 3 coils cut on each. Car actually rides good like this
