Gentlemen, We're ready to order a set of rear tires (Coker) for the car and wanted to confirm the correct size to meet the 6 inch maximum width rule. Are the L78's the correct size? I'll be taking some pictures of the car as soon as the tires are mounted. I'm pretty happy with how it's turned out so far. Now, if I had the engine built...... I'll see all of you at MoKan in a couple of weeks. Thanks, Ron
Yes, L78 are fine. G78 are almost as wide, but are shorter, if you're into that sort of thing. Be sure and join the HAMB alliance and get your discount.
Just for refference sake, the L78 is what most of us here in Oz are running, and promote to all to use, as we've found them to be really great, consistant, and effective. Cheers, Drewfus
