Cold air intake hose
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Dec 29, 2013.
  1. need louvers ?
    need louvers ?
    Hey gang,
    I know to some this might be construed as something a little outside the scope of the H.A.M.B. and maybe more "muscle car", but ***ure you it's not.
    I am in the process of modifying "endlessearth's" stock air cleaner for his '64 C10 to do a double tube cold air intake, ala the Ford Thunderbolt Fairlanes of the early sixties. I did this same thing with the Plymouth when it still had inner fender panels about ten years ago, and in the summer heat here, it really made a difference in drivability concerns
    The only thing I didn't like on mine was that I never found a good supplier of a hose the appropriate size, and I used corrugated aluminum drier hose... Not what I want here!
    My question is this - has anybody found a good source for a soft wire reinforced hose that is either 3" or 4" in approximately four foot lengths? I'm talking the stuff like G.M. used back in the seventies and eighties to do the same, but in longer lengths.
    Anybody?
  2. davidvillajr
    davidvillajr
  3. GeezersP15
    GeezersP15
    from N.E. PA
    Not sure if they have it, but an excellent place to look for stuff like this is
    McMaster-Carr. Maybe you've already looked there, but if not, give it a try.
    It's like the world's ultimate hardware store, and they ship extremely fast. They're primarily an industrial supply company, but they will sell to individuals also.
    Wayne
  4. choptop40
    choptop40
    check out your local a/c , heating supplier , they have all kinds of flexible hoses , ductwork etc....git er done.....happy new year
  5. gimpyshotrods
    gimpyshotrods
    I'm interested in this too. Looking for an OEM apoearing hose, and not bling.
  6. Mike51Merc
    Mike51Merc
    An engine is essentially an air pump. What goes in comes out. If the thunderbolt needed two 8" air hoses, it would also have needed two 8" exhaust pipes.
  7. need louvers ?
    need louvers ?
  8. need louvers ?
    need louvers ?
    I sat down with the McMaster - Carr "phone book' a couple of times and found stuff I would call close, but no cigar. But thanks.
  9. need louvers ?
    need louvers ?
    The only way I could see that working better is if it's sealed off from the engine compartment and coming through the hood or fresh air ducting like they did in Nascar stuff back in the seventies. By opening the radiator core support, you are also giving incoming air a way to byp*** the radiator, which maybe in your neck of the woods is no big deal, but on a typical 120 degree day with the A/C clucking along to keep you alive it does become a HUGE deal very quickly. I will take a bit of time and check out the French black drain duct that you used though.
  10. gimpyshotrods
    gimpyshotrods
    Internal combustion engines do not work that way.:eek:
  11. HOTRODPRIMER
    HOTRODPRIMER
    My brother-in-law is in the heat & air business and I could swear i saw a piece of black flexible hose in his truck when he was working on my heat pump..I didn't think much of it at the time and don't know what size it was.
    You might check with some of the heat & air guys. HRP
  12. palosfv3
    palosfv3
  13. Dave Downs
    Dave Downs
    from S.E. Penna
  14. need louvers ?
    need louvers ?
    That looks like they might be able to help.
  15. Rusty O'Toole
    Rusty O'Toole
    Might be better and easier to tap into the fresh air duct ahead of the windshield. Closer to the air filter and it is under pressure when the car is at speed. All you need to do as a rule is cut a hole in the firewall and rig up a short flexible hose.
  16. kursplat
    kursplat
    check the junkyards, lot's of 80's up cars have those hoses in different configs
  17. super-six
    super-six
  18. Oh boy !!!
    There's no place to start on this one.
  19. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Might want to rethink this :rolleyes:
  20. blue 49
    blue 49
    from Iowa
  21. loudbang
    J.C Whitney used to sell it and scoops for under the bumper. Not sure it they still sell it though.
  22. Mike51Merc
    Mike51Merc
    OK guys, I'm aware of different densities, etc. and I was exaggerating to make a point.
    Do you guys believe that the Thunderbolt needed two 8" diameter hoses to properly feed its intake?
  23. 325w
    325w
    Gates used to sell the hose. Came in about a five foot length. Been along time but I think a big truck application. Used on a 54 power steering Chevy.
  24. FOURTYDLX
    FOURTYDLX
    Try the people that sell table saws, Or your local cab shop's, they use that type of hose in dust collection.
  25. Joe H
    Joe H
  26. jwray
    jwray
    from Omaha, Ne
  27. models916
    models916
    Stock car suppliers sell lots of this flexible duct. 3" is for brake cooling duct.
  28. tfeverfred
    tfeverfred
    Hahahah.....WHAT?
  29. 1941ihkb5
    1941ihkb5
    Grainger has over 100% mark-up on a lot of tools! The Aircraft Spruce looks to be the best deal. Havn't looked at Mc Master or MSC yet. I plan on doing something like this on my A-100 pickup.
