Cold symptoms after welding?
Discussion in 'The Hokey Ass Message Board' started by Scott, Nov 20, 2007.
  1. plym_46
    plym_46
    from central NY
    Just Kidding, I know first had about galvanized as I used a liberated street sign for a shock tower brace. It was not a pleasant experience and after only two short welds.......
  2. jeffrob
    jeffrob
    first day of welding cl*** the instructor says two things:
    1. If you ain't got a puddle you ain't got ****.
    2. Don't weld galvanized, it can kill you.
    I always use a BIG fan, after today when blowing my nose & seeing all that black **** I decided to get a respirator that will fit under the hood.
  3. JamesG
    JamesG
    My old man has Welding induced Parkinson's (manganese poisoning). Wear a resporator people.
  4. Scott
    Scott
    Not galvanized
    An update , about 48 hours later and the symptoms seem to be subsiding:) I dont want to go thru that again!!!!
  5. nexxussian
    nexxussian
    ****s, don't it?
  6. povertyflats
    povertyflats
    from Missouri
    Doc, I still think you're crazy but a heck of a fun guy!
  7. Florian
    Florian
    I heard that electrowelding is very bad for your lungs, but is this the same with MAG or MIG welding then??
  8. All welding, anything that super heats any metallic item is BAD for you. I work in the medical profession and see a lot of older boilermakers with some seriously bad lung disorders. Some think its un-cool to weld with out a respirator but I have seen the results of that. I wear on for welding, grinding, cutting, buffing etc..........
  9. NVRA #84
    NVRA #84
    Where does this air come from thats blowing down past your nose?
  10. rustfarmer
    rustfarmer
    from Hawaii
    Did you say cold symptoms after WEDDING?
  11. Reverand Greg
    Reverand Greg
    Do your self a favor and drink some milk to counteract the poisonous fumes and get some sort of air mover get the fumes away from the area.works like a charm
  12. Most MIG filler wire is coated with copper and it sure isnt going into the weld, its ending up in the atmosphere that you breathe, in our factory there is only ever 2 max 3 people welding at any moment and the haze that hangs in the ceiling is very thick, but the WORST process ive used is air-arc gouging- the consumable electrode is made of carbon and encased in a thin copper tube. it gets blasted back into the atmosphere by the 100psi air stream used to purge the slag. you feel very bad the night after you use one. ive faced the fact that my profession will send me to an early grave.
  13. HHRdave
    HHRdave
    from So Cal
    Doctors say it can take a week for the incubation period for the germs to make you have a cold/sickness. I doubt you got it from welding.
  14. KustomF100
    KustomF100
    from Joliet, IL
  15. Scott
    Scott
    Got back to it today, wore the respirator for cutting grinding and welding. It was more comfy than usual:D
  16. sliderule67
    sliderule67
    from Houston
    Look up "Metal Fume Fever"; should be a lot about NOx, heavy metals, etc. Good ventillation is mandatory.
  17. publicenemy1925
    publicenemy1925
    from OKC, OK
    Doing body work everydayi've been there before. Normally I get it from welding in trunks, like floors,rear body panels, inner wheelhouses. I always try to have a fan blowing in the general direction just not where the welding is happening. I also wear a mask. A carbon filter is the best. It lasts about a day, depending on how much you inhaled. Can be as bad as puking and the ****s like food poisoning with a fever. Not my favorite thing in the world. Ventillation is the key along with a good mask.
  18. Crease
    Crease
    Welding is bad for ya, but welding galvanized stuff is realllly bad for ya.
    You should know by now that anything fun requires proper protection.
