Technical Cold Welding
Discussion in 'The Hokey Ass Message Board' started by Flathead Dave, Apr 24, 2020.
  1. Flathead Dave
    Flathead Dave
    from So. Cal.
  2. Mr48chev
    I don't see where it would be practical for an individual to do or attempt to do on a vehicle.
  3. oldiron 440
    oldiron 440
    Results may vary......
  4. Looks like tig with no filler rod ?
    Tommy
  5. Torana68
    Torana68
    from Australia
    It’s BS all he’s doing is melting (with heat!!) the surrounding metal so it flows together, no filler rod.
    Desoto291Hemi likes this.
  6. Sandgroper
    Sandgroper
    Interesting, just googled it, only for non ferrous metal. I'll keep using the mig, and arc on aluminium. :D
  7. AVater
    AVater
    So if it’s cold, why doesn’t he touch it?
    warhorseracing and Texas Webb like this.
  8. Hnstray
    Hnstray
    from Quincy, IL
    In cl***es by Ron Fournier I took several years ago I seem to recall that being referred to as ‘fusion’ welding. Very tightly fitted joint and no filler rod required. However, it was .062” aluminum and oxy/acet torch. I don’t see any reason it couldn’t have been done with tig, but Ron was teaching gas welding technique at the time. I really don’t comprehend the term ‘cold welding’ in this application unless it is a relative term, as heat is clearly being applied.
    Ray
    Budget36 and Desoto291Hemi like this.
  9. TRENDZ
    TRENDZ
    It is just fusing the two metals. Tig set on scratch start with high amperage for short duration. Depending on the time you choose between starts, the m*** of the part stays fairly cool. This wouldn’t be used for structural parts.
  10. boltupal
    boltupal
    from western ny
    So Dave how cold is it ? 20 below zero? Could I use it to keep my beer cold ? Or is it just tig parts together without filler rod?
    AVater likes this.
  11. sliceddeuce
    sliceddeuce
    A.K.A. Autogenous welding. No reason to do it other than tacking an ***embley
    Blue One and Desoto291Hemi like this.
  12. Flathead Dave
    Flathead Dave
    from So. Cal.
    Ask them.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    They do in other videos. That's why I was curious about it.
  14. squirrel
    I can't understand a damn thing that he's saying.
  15. 51504bat
    51504bat
    Is this anything like the guys at swap meets that used to sell miracle rod for gas welding aluminum? IIRC they used to have a bunch of beer cans that they welded together with the miracle rod.
    triumph 1 likes this.
  16. Blue One
    Blue One
    from Alberta
    Very short pulses of enough amperage to melt and fuse the metals.
    As mentioned autogenous welding fusing metal without filler rod except in a couple of spots where the gap between pieces needed a little filler.
    Non ferrous metals only is correct.
    Cold welding ? not a chance :D Don't kid yourself when you melt and fuse metal there is heat involved.
    Will the heat affected zone be tiny ? Yes.
    Will it cool quickly ? Yes.
    If he touched the weld too soon after it was done could he burn himself ? Yes.
    Should they learn to speak English ? Yes :D
    Will it do a weld without much damage to the paint ? Possibly but why would you want to do that ?
    I can't imagine welding a tear in the aluminum body of my F150 truck and worrying that I could keep the paint intact. (along with having a big ol Frankenstein style weld scar :D)
    Oh but look the paint is still good :D
    Practical for anything we do ? Not really.
    loudbang, duncan and Desoto291Hemi like this.
  17. squirrel
    But how strong is the weld?
    Cosmo49 likes this.
  18. dreracecar
    dreracecar
    from so-cal
    More commonly know as "PULSE" welding, My MILLER Dynasty comes with that feature and is very tunable as towards pulses per second, primary heat and secondary heat. Really helps in keeping the warpage down because it consentraits the heat and then cools. so you are not pushing a lot of heat forward
    ottoman likes this.
  19. lake_harley
    lake_harley
    I believe I might have flash burned my eyes watching the video without a welding helmet.
    Lynn
    Blue One and winduptoy like this.
  20. Flathead Dave
    Flathead Dave
    from So. Cal.
    That's what I want to know. How is the penetration.
  21. Petejoe
    Petejoe
    from Zoar, Ohio
    A tig weld with a perfect joint and fused without rod is just as strong as any tig weld. Being younger with good eyes and a steady hand I used to weld the stainless seams on tank trailers without a rod.
    Perfect fusion and penetration is possible. We are talking sheet metal normally but even thicker metals will behave the same with the right torch that provides enough heat and can be controlled properly.
    Cold welding??
    No such thing. Metal won’t fuse without A heat source.
    warbird1, gimpyshotrods and alanp561 like this.
  22. alanp561
    alanp561
    Depends on how thin the parent metal is, how much gap is involved, what the amperage is and how fast you move. One of those things that people who weld two razor blades together would do. I went to a swimming pool manufacturer one time to test for a job building stainless swimming pool liners. Extremely thin stainless with no gap. You had to run a downhill p*** fusing the sheets together without a filler rod. Trick to it was turning the heat up and moving fast at a constant speed. No walking the cup. When you were done, there was 100% penetration and very little warpage. That's the only practical application for it I've ever been involved with.
    Flathead Dave and Petejoe like this.
  23. alanp561
    alanp561
    The weld itself would be as strong as the parent metal but the area immediately adjacent to the weld , usually showing up as a narrow blue line on carbon or stainless steel, would only have 85% strength of the parent metal.
    Flathead Dave, Petejoe and Cosmo49 like this.
  24. gimpyshotrods
    gimpyshotrods
    Correct.
    The term is autogenous welding. Cold welding is not a term.
    I have been using this process for tightly-fit sheet metal, for decades, with no issues.
    warbird1 and Flathead Dave like this.
  25. gimpyshotrods
    gimpyshotrods
    The technical term for words that are popular, but used incorrectly is: wrong.
    Hnstray, Fortunateson, X38 and 2 others like this.
  26. G-son
    G-son
    from Sweden
    Duct tape can also hold metal pieces together, with no added heat. I think I'll stick with that, when the O/A torch is too hot.
    gimpyshotrods likes this.
  27. TRENDZ
    TRENDZ
    I’ve cold welded freeze plugs in my motor with good results.
    J. A. Miller and Flathead Dave like this.
  28. Blue One
    Blue One
    from Alberta
    :eek: He said penetration :D:D:D:D
  29. Flathead Dave
    Flathead Dave
    from So. Cal.
  30. Fortunateson
    Fortunateson
