Technical Collapsing Upper Radiator Hose
Discussion in 'Traditional Hot Rods' started by KPowers, Nov 24, 2024.
  1. KPowers
    KPowers
    20241124_150858.jpg 20241124_150909.jpg [​IMG]Need an education on why an upper hose would collapse
    • basic SBC
    • just added catch can - makes me think this is prob but dont understand why
    • catch can has rad hose and overflow line
    • cooling system works perfect holds temp no issues
    • cooling off and upper hose collapses
  2. Happydaze
    Happydaze
    Is your radiator cap of the type that have a return facility? There should be a round, spring loaded flap in the centre. You can gently pull it away and it should spring shut. It allows expelled coolant to be drawn back in when the system cools and contracts. You also need the hose in the can to be under the fluid so it can be drawn back in ( its a recovery tank, not a catch can). Sounds like you have the wrong cap, fluid is expelled but in cooling there's no way to pull coolant back so the system collapses the weakest point.
    Chris
  3. KPowers
    KPowers
    Thank you Chris, Ill check the cap style
  4. Catch can also needs to be vented.
    Black_Sheep, dirt t and mad mikey like this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    The overflow in the recovery tank is open to the atmosphere...in most cases
  6. I should have said "be able to" vent.
    mad mikey likes this.
  7. BJR
    BJR
    If the upper hose is collapsing it has to be the cap not letting air or coolant back into the radiator as it cools.
    Black_Sheep and RodStRace like this.
  8. KPowers
    KPowers
    yes, to clarify the recovery tank has two lines on bottom, one coming in from radiator cap and is flush to bottom of tank, and an vent/overflow line that extends into tank about 5in, attached to rubber line down to bottom of frame.
    Will take pick of cap once cooled off.
    2OLD2FAST likes this.
  9. Happydaze
    Happydaze
    Recovery can / tank sounds right. Just seen the pics. The convoluted hose is more stretchy than molded hose. Is there a spring in there? There is in mine. Also, I see a convoluted bottom hose. There has to be a spring in there as otherwise its liable to collapse under suction from the waterpump.
    Cooled yet?
    Chris
    alanp561 likes this.
  10. Fortunateson
    Fortunateson
    My Dad always referred to those as Puke Boxes! LOL
  11. Rodney Dangercar
    Rodney Dangercar
    I have that same catch can, works like a charm. Your radiator cap is the wrong type or the valve for coolant return is jammed.
  12. KPowers
    KPowers
    I think it actually has the vacuum valve, but might be gummed up or not working. when i pulled it away from gasket there is some crud in there.
    makes sense, reason im even messing with this is I was doing a cooling system flush.
    will try and clean out cap, and then find a new cap if necessary. 20241124_171610.jpg
    Happydaze likes this.
  13. Happydaze
    Happydaze
    That's the correct type of cap!
    Stumped now!
    Chris
  14. Clydesdale
    Clydesdale
    Where the hose from the rad loops under the recovery tank, is the bend nice and wide? Could it be kinked or tight enough to close up under vacuum?
  15. Budget36
    Budget36
    Had the same issue on my daughter DD, OT but SBC-not LS, etc. I think it was @31Vicky with a hemi who steered me in the right direction.
    It did solve it, but search thread topics from 4/6 years back started by me.
    If I could remember what I did, I’d tell ya!
  16. BJR
    BJR
    That was helpful. :D
    Budget36 and 5window like this.
  17. Oneball
    Oneball
    When the top hose is collapsed remove the overflow pipe from the radiator neck. If air is ****ed into the radiator and the top hose returns to normal yoir problem is in the catch tank or it’s pipe work. If nothing happens and the top hose stays collapsed the problem is to do with the rad cap.
    jaracer, 2OLD2FAST, X-cpe and 3 others like this.
  18. KPowers
    KPowers
    when I cracked cap open it released the vacuum, will clean cap or buy new one see what it does.
    also was an ebay radiator so would not be totally shocked if cap was a throw away.
    will also double check recovery tank lines.
    Happydaze, 5window and Clydesdale like this.
  19. KPowers
    KPowers
    7 Dollar NAPA cap resolved it, letting fluid move in and out of recovery 20241125_143912.jpg tank.
  20. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    It wouldn’t hurt to put a fairly “strong spring” inside of top radiator hose in question to make sure it doesn’t collapse because of some strange thing happening in the water supply system!!! IMG_2651.jpeg IMG_0749.jpeg IMG_2352.jpeg
