Columbia overdrive question
Discussion in 'The Hokey Ass Message Board' started by deuceV8, Jul 23, 2012.
  1. deuceV8
    deuceV8
    Does anyone know the ins and outs of what it takes to convert a 40 ford columbia rear to electric rather than vacuum?
  2. StrickV8
    StrickV8
    talked to josh?
  3. dana barlow
    dana barlow
    from Miami Fla.
    I was told that a chockcable can work;)
  4. tinmann
    tinmann
    I happen to have a Columbia, minus all the vacuum controls, so I think I shall wait here on the sidelines to see where this thread leads.......
  5. Steve-Cook
    Steve-Cook
    from Garner, NC
    mine is electrically activated and pneumatically actuated
    In other word you choose weather you are in OD or not through a electrical toggle switch but engine vacuum is used to control the position of the differential actuation canister.
  6. fordcragar
    fordcragar
    from Yakima WA.
    Mine was set up to be shifted manually.
  7. deuceV8
    deuceV8
    not yet but I definately will
  8. 35cab
    35cab
    I have one in my 35 , used an electric control valve but still working off the vacuum from inlet. I think these controls are used for switching fuel tanks on trucks.
    Check out www.columbiatwospeedparts.com
  9. duste01
    duste01
    The change that you are referring to is comprised of the actuator on the axle housing itself. Thats the business end of the switching of the axle from high and low. Columbiatwospeedparts sells such an animal and John is a great guy to talk to. The rest of the controls however work in concert to make the switch behind the dash so your speedometer reads what your rear end is doing. John sells some of those pieces too, SOME, not all. I have restored all the controls for mine and still had to work around the missing neutral safety switch. Lots of little stuff involved in it all, or you can make as simple as a manual lever if you know what your doing, and can live without.
  10. tommy
    tommy
    I've never done it but I have read where a fellow used a modern dual gas tank selector valve from a P/U to direct the vacuum to the correct side of the actuator. It's already 12 Vs and once figured out it will direct the vacuum to put it into OD or pull it out of OD. You will have to understand how one works to figure it out but it is pretty simple and cheap once to figure out the vacuum routing.
  11. OoltewahSpeedShop
    OoltewahSpeedShop
    Mine has cable. See chrome knob under dash.
