Column mount ts switch with brake lights????
Discussion in 'The Hokey Ass Message Board' started by Mr48chev, Nov 24, 2010.
  1. Mr48chev
    I guess I should make it a bit more clear than the ***le.
    Does anyone know of a column mounted aftermarket turn signal switch that you can run brake lights through so as to only use one bulb for stop and brake lights?
    Every one I can find uses a separate bulb (light) for the brake lights.
    I'm talking about the one that clamps on the column and not in the column or a converted one under or in the dash.
  2. BADBIRDCAGE
    BADBIRDCAGE
    from Virginia
    NAPA carries one for trucks under the LIT code. IIRC it is part number 700. Lots of guys use them on field trucks and dump trucks.
  3. mj40's
    mj40's
  4. J&JHotrods
    J&JHotrods
    Couldn't you use a combo bulb(1157) and purchase two 3-wire pigtail sockets? Wouldn't that be a cheaper alternative, or am I missing something?
  5. JohnEvans
    JohnEvans
    from Phoenix AZ
    Any of the aftermarket 7 wire switches will let you use the same bulb filament for TS/brake functions.
  6. Aquaroscoe
    Aquaroscoe
    Something like a signal stat 900?
  7. Da Tinman
    Da Tinman
    yep,, and if you have seperate bulbs in the housing you should swap in 1157 bulbs and sockets. easy as pie.
