Gents, I am considering putting a 40 sideshift gearbox in my 31 roadster when I drop in the flathead. Pardon me in advance if this has been covered but what column is best for this? I have an F-1 unit with out the column shift that I had planned on using with my topshift ****** and a 46 or 47 car steering column with a shifter I ended up with years ago...it doen't look like the 46-47 unit will work with out some big work. should I look for an f-1 with the column shift or...? Thanks, Bakersfield Boy
I Have 51 Fi Truck With Column Shift I Just Changed Over To A 51 Car Wheel And Tube . As Far As I Can Tell 1940 An Up The Shift Mechanism Stuff Is All The Same It All Fits With A Little Work. My 2 $
I remember when some of the hoodlums in my neighborhood would change the column shifts to the left hand side of the column. This was in old Fords. This was a long time ago but I think it was for a faster shift into second gear. I think they pulled the lever to shift into second gear.
