Comfortable/safe cruising speed?
Discussion in 'The Hokey Ass Message Board' started by cmarcus, Jul 29, 2013.
  1. cmarcus
    cmarcus
    Hey guys! I am getting ready to prepare for my first shakedown run/cruise in the '50 and wondering what you guys feel is a "safe" and comfortable cruising speed in a car like mine without feeling like you are going to grenade the damn thing.
    It is ALL factory drivetrain, 216, 3-on-the-tree, factory brakes, and I have new radials on it.
    50? 55? 60? What do you feel comfortable at?
  2. 50desotocoupe
    50desotocoupe
    from Denver
    I have a 50 Desoto and felt comfortable at 65-70...of course it depends on where that is......city highway or country. I tend to slow down in the city because of all the OT cars that don't seem to realize you are even around.
  3. belair
    belair
    For that car, 55-65 is enough. A 216 will go faster, but the faster you go, the sooner it's gonna burn a rod (if it's a dipper). Brakes need to be adjusted up good too. Gotta stop straight when that texter pulls out in front of you and you hit the brakes.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I don't think I am in the position to suggest a set speed,,you own the car and should have a good feel for it.
    The engine can grenade just as easy at 35 as it can at 55,,it's just a matter of when it decides to let go.
    Go out and enjoy yourself if the worse decides to happens it's time for a small block! :D HRP
  5. Studebricker
    Studebricker
    from TX
    Exactly. Depends on how many other cars around you. I can go 60-65 on the freeway alright, but that is with plenty of room in front to stop with drum brakes. If it's a crowded road, I would drop down to 55 to leave plenty of room.
  6. VoodooTwin
    VoodooTwin
    from Noo Yawk
    For a fresh build, I go up and down my driveway (about 800 feet) first, about 5 mph to listen for anything weird, check the brakes, check the operation of the e-brake, etc. If that goes well, a ride around the block at 25 mph. If that goes well, a few rides further down the street and around town at 30-35 mph during off-hours. Once I'm confortable that it's G2G, I'll run it up at highway speeds.
  7. lc1963
    lc1963
    from iowa
    It would depend on your rear gears also.
  8. Rattle Trap
    Rattle Trap
    When she feels all wound up, Push the pedal just a little more. :)
  9. cmarcus
    cmarcus
    HAHAHA! Thanks guys, it is a dip system/splash set up, so I know you have to be careful. Some people tell me to keep it at 50, some have said you are ok up to 65 ish. Just so hard to know, and obviously I don't want to blow up a motor I just put work into - better safe than sorry!
  10. B1gDaddy
    B1gDaddy
    from aladambama
    I would be mostly concerned with the brakes at first that checking the upper limits. Drive around the neighborhood first to get a feel for what the brakes act like at speed.
    Lots less hazardous to your health too if you have a need to stop in someones driveway and check something out.
  11. wizzard23
    wizzard23
    My old 47 with stock drive train (4:11 gears) and 1962 235 liked 60mph.
  12. Mr48chev
    You will find where you are comfortable with it but I'd guess in the 55/60 mph range for the 216 is about the limit of it's comfort zone.
  13. THis car is pre-interstate. 45 was considered pretty fast. I'd keep it under 55-60.
    Remember, too, in this era, you got what you paid for. By that, I mean the more money you paid for a car, the better the car. So, a DeSoto will be able to go faster than a Chevy, A Cadillac faster than the DeSoto. A ford, not so much, though the V8 DID change a lot of this hierarchy.
    Cosmo
  14. Phils49and56
    Phils49and56
    55-60 should be fine in that thing, you never really are safe with all the idiots out there texting and talking on the damn phone anyways, get in, throw on some tunes, stick your right arm out the window and cruise brotha
    "You know a guy around here with a piss-yellow deuce coupe?
    Supposed to be hot stuff?
    You mean John Milner?
    Ain't nobody can beat him, man. He's got the fastest--
    I ain't nobody, ****. "
  15. belair
    belair
    I was referring to my stock 48 Chevy. It would DO 80, but that brings up the burned rod...
  16. cmarcus
    cmarcus
    That is the plan Phil! Was just curious as I am planning a slow cruise from Holland, MI to Hickory Corners, MI for the Relix Riot, which is around 65 miles, and I'll plan 2 hours to get there. Cannot wait!
    The main reason I was curious is I need to eventually get this thing down to the Western suburbs of Chicago, which will take REAL good amount of time with backroads. Around NE Indiana/SW Michigan, and west of there into Illinois, backroads are not "ideal" for a number of reasons...namely neighborhoods... :(
  17. 61 chevy
    61 chevy
    too slow, and someone will dog you, 55 ,have good brakes, good sterring
  18. czuch
    czuch
    from vail az
    I always term it a "Break down", instead of a "Shakedown" cruise.
    Easy and slow in the neighborhood when the kiddies are put away.
    Check to see if the brakes pull left or right, general feel. THEN GO,BABY!!!
  19. Boones
    Boones
    from Kent, Wa
    55 mph, maybe 60. I know at 65 I felt like I was pushing my 51 chevy
  20. plym_46
    plym_46
    from central NY
    Remember that these cars were built to move people from one place to another, that the states built roads to accommodate them, and that people actually used them to go to work, on family outings, and to cross the country. Now back in the 50's limited access multi lane super highways were few and and far between but most state highways were posted for 55 to 60 MPH in rural areas. Cars were designed accordingly. So as a rule of thumb, take your factory Peak HP RPM, which for a 1950 216 Chevrolet was 92 at 3400 (235's were rated at 3600 probably because of better bearings and oiling), and use 80% of that for a safe cruising speed which is about 2800 RPM. If you don't have a tach, you can figure this out on some online calculators, by entering your tire diameter, about 27.5 inches for 600/6.50 15's, then your rear end ratio, and your top gear ratio, usually 1 to1 unless you have OD. My Plymouth has a 4.11 rear end and I run a 28 1/4 inch tire. At 62 I am at 3280 RPM which works out to 82% of my cars 3600 Rpm peak HP engine speed.
    Let's say your car has a 1 to 1 top gear, a 3.89 to 1 rear end, and a 27.5 inch tire, 2800 RPM gives you 59.8 MPH. Taller tires would either give you a couple more mph or lower your rpm for a given speed.
    We have taken several long trips 400+ miles in our car. I usually take the state highways and cruise around 60. When I get to a city or congested area, I will jump on the Interstate or expressways. I do this because I think it's easier on the car to keep rolling on at speed that to stay on the surface roads with all the stop and go. Once the congestion is behind, I get back on the state roads.
    I usually break down my long trips into 50 or 100 mile segments. I figure if ti goes 50 miles it will go 100, ad so on. Good luck on your adventures. You will gain confidence in your ride as you put some miles on the clock.
  21. stay with it until you can't stand no more or until the law tells you it just to dam fast. But good luck and hope it is a safe shake down
  22. finn
    finn
    I grew up in the 50's and 60's. Speed limits on the rural roads in Michigan were 65mph.
    My dad had a 53 Ford flathead with and then a 57 Ford DelRio 2dr wagon with a 272 Y block. He was a conservative driver, but I remember he always cruised a couple of mph above the speed limit---~67 or 68 mph.
    Those cars never used oil and still ran well when he traded them at 60-70k miles, which was probably typical for the period.
    His later cars, a 61 Y block and a 65 Galaxie cruised well at 70-75 after the Interstate system was being constructed, but both of those cars had taller gears.
  23. TheTrailerGuy
    TheTrailerGuy
    It's your car and you know how much repair money you have in reserve, drive it accordingly.
  24. 48FordFanatic
    48FordFanatic
    from Maine
    My Ford with a SBC really likes 80 on the I-state.
