Hot Rods Compact HEI ?
Discussion in 'The Hokey Ass Message Board' started by AngleGrinder, May 16, 2021.
  1. AngleGrinder
    AngleGrinder
    Greeting all.
    Currently I have the MSD Distributor, ign box and coil. Hoping to replace all that with the HEI style distributor but it measures 6 inches across at widest point. Does not fit behind the 327/300hp motor..
    Rather not cut up the firewall, move my gas pedal, move under dash stuff etc.
    Do you have any suggestions ? Is there a compact HEI ? go with separate coil
    distributor ? Last resort is to cut. hey thank you.... Angle Grinder
  2. jaracer
    jaracer
    I think MSD makes one. I had one made for my Buick by Dave's Small Body HEI. However, if you need it in a timely fashion I don't recommend him. While his work is very good, I think he had my distributor for 10 months or more.
    AngleGrinder likes this.
  3. badshifter
    badshifter
  4. rockable
    rockable
    Or use a Pertronix Ignitor II. That's what I did on my 57. Comes with all the springs and weights to customize your advance curve, too.
  5. squirrel
    Or leave the points in it, and have a nice reliable ignition system, that is HAMB friendly. The tough part is finding an original 1960s distributor, they're so much better than the modern replacements.
    but what do I know, the pic in my avatar shows me chasing an elusive ignition condenser issue....
  6. Dave G in Gansevoort
    from Upstate NY
    You need one of these. Not used much anymore but when needed... 20201002_145733.jpg
  7. bobkatrods
    bobkatrods
    from aledo tx
    As suggested,use a point dizzy, add a MSD unit under dash.Get a nice spark and if MSD acts up on the road a simple jumper wire will by p*** the unit,Easy enough to swap points on the road also,,I have the exact setup ..
    31hotrodguy likes this.
  8. squirrel
    How hot of a spark do you need? I've been in the nines with a stock coil....triggered by points...no electronics.
  9. okiedokie
    okiedokie
    from Ok
    Yes there are. I dont recall the name of the guy but maybe Jasons small body HEI dist.
  10. rockable
    rockable
    Unless you use an external coil, there will be no smaller option. The HEI coil is what makes the distributor so large.
  11. fastcar1953
    fastcar1953
  12. justpassinthru
    justpassinthru
    Allstar markets a ready to run dist that is just like the MSD ready to run unit. It is almost 1/2 the price of a MSD. It is a small cap and runs a separate coil and doesnt need the box. We have used them a number of times, without issues. Maybe its even made by MSD for Allstar?
    Bill
    AngleGrinder and loudbang like this.
  13. 1934coupe
    1934coupe
    What is wrong with the MSD that you want to change it.? I for one am not a fan of Petronix, I know as many people that have had problems with them and an equal amount that swear by them. Never been stranded with stock stuff or MSD.
    Pat
  14. ffr1222k
    ffr1222k
    1990 Camaro Z28 used a small HEI distributor and a remotely mounted coil. You would need the connectors to plug into it.
  15. Mr48chev
    That one is computer controlled and defeats the purpose though. Same distributor was used up though the end of small blocks and big blocks with actual distributors.
  16. oldolds
    oldolds
    Use a stock points distributor with a Ford FAST system hooked up to it. I do not have info on how to do it. Computer crashed. It is pretty easy. look it up. Points are only a trigger for it
  17. Ebbsspeed
    Ebbsspeed
    Proven salvage yard solution at the link below. Use a "traditional" small diameter points distributor and coil, hide the Ford TFI module under the dash, drive it. This solution can also be "rewired on the road" and run as a normal points system if there is a TFI module failure.
    If you really want to go nuts, you can wire the points and coil through a DPDT relay powered via a toggle switch. If the Module fails flip the switch and keep driving.
    https://www.49ccscoot.com/manuals/FORD TFI electronic ignition.pdf
    AngleGrinder, loudbang and egads like this.
  18. AngleGrinder
    AngleGrinder
    Thanx Jaracer, much appreciate your reply. Kinda need to be driving my coupe soon or go crazy. cheers
  19. AngleGrinder
    AngleGrinder
  20. AngleGrinder
    AngleGrinder
    Thanx Rockable !
  21. AngleGrinder
    AngleGrinder
  22. AngleGrinder
    AngleGrinder
    Looked it up, looks good. thanx man.
  23. JWL115C
    JWL115C
    Taylor Electronics makes a distributor that looks like a Vertex Magneto. I have one on my 55 Dodge 270 Hemi. No vacuum control, but no problem.
    31hotrodguy and AngleGrinder like this.
  24. Truckedup
    Truckedup
    You are looking at the front of the engine in the avatar..coil and or condenser mounted remotely or, god forbid, is that a Ford engine? :D
  25. squirrel
    I was playing with spark plugs, actually...I didn't figure out the condenser problem until several months later.
  26. Budget36
    Budget36
    No advance in that.
  27. AngleGrinder
    AngleGrinder
    I'm leaning towards an MSD 8360 "ready to run" distributor, external coil that will fit at 5 inches across. No ignition box required. Get a black cap and black wires. Any comments ?
    Seth Bilodeau and Hnstray like this.
  28. saltflats
    saltflats
    from Missouri
    Can't find a points distributor?
  29. Blake 27
    Blake 27
  30. deathrowdave
    deathrowdave
    from NKy
    I ran a mag on the street for a while . Not the best choice . I run the points and condenser without any issues . If you drive lots once a year swap to new guts and your good to go . I have owned 428 and 429 SCJs hard not one issue with stock coil and points . Thing about it , they worked on lots of HP stuff for years
    AngleGrinder and 31hotrodguy like this.
