compare edelbrock performer and Weiand warrior
Discussion in 'The Hokey Ass Message Board' started by Double Caddy, Apr 24, 2011.
Edelbrock performer or Weiand stealth
Poll closed Apr 29, 2011.
  1. Edelbrock performer intake
    1 vote(s)
    100.0%
  2. Weiand stealth
    0 vote(s)
    0.0%
  1. Double Caddy
    Double Caddy
    from virginia
    I have to Replace my c-396 edelbrock dual plane intake oval port head on my 454. Whats a better option??? I have a crack where the threads for the heater fitting . and its cheaper to replace the intake around $200.00 than the fix around $400. I would like to know what has the better performance. Weiand or edelbrock. I am running edelbrock 750 cfm carb, mild blue racer cam. Full length headers, hei distributor, stock long block 73 454 with oval port heads. And 2 1/2 inch dual exhaust. In the ***le I said warrior but I meant Stealth. I also was looking at the Ofenhauser dual plane intake also
  2. Deuces
    Deuces
    Does Edelbrock make a Performer air gap intake for oval port heads??? if so, then I vote for that one... :D
  3. ClutchDumpinDan
    ClutchDumpinDan
    Todd, before you buy a new intake, bring it on over and I'll see if I can fix it. Didn't seem $400 bad from what I remember :D
  4. Deuces
    Deuces
    Let's see a picture of your busted intake please.... I'm sure it can be repaired for alot cheaper than 400 sheckels....
  5. Double Caddy
    Double Caddy
    from virginia
    good talking to you Dan. I will try to bring it over this week to have you take a stab at it .
  6. Double Caddy
    Double Caddy
    from virginia
    I got the intake back on today. DAN did a bang up job of welding up my manifold. The intake was not cracked just the front half of the threads were gone. Since I dont have a heater in the car the easiest was to put in a aluminum plug in and weld it up. Dan does really nice work . He even cleaned up the manifold it looks like I got a new one. Once I got the timing straightened out. She fired right up. On my first attempt it was 180 degrees out , got a great big back fire. Took her out for a quick drive and guess what?? no anti-freeze on the front of the engine. Tomorrow I will drive her somemore so I can retorque the intake. Thanks again Dan.
  7. chevyshubox
    chevyshubox
    from Australia
    Thats great news on the repair. Cheaper than a new one thats for sure. Anyway I would have said Performer RPM Airgap followed by the Performer RPM or the stealth. I have tried them all and the last two went the same with the air gap just picking up a little bit over the other two with no other changes.. They all liked a 1" spacer or even a two inch on the later two but I am yet to try a 2" on the air gap. All these are a great manifold.
    I actually have the old Performer spreadbore type on my 454 56 Chevy and it runs low 11`s with pretty well stock motor just a fairly mild cam and stock heads with a 850 DP. Big convertor and low gears beacause this is what I had
    Any way as you can tell I love dual planes on heavy cars.
  8. ClutchDumpinDan
    ClutchDumpinDan
    Thanks! I'm glad it did the trick :D
