What's a compatible gas tank for the 39/40 merc coupe? I'm filling in the filler neck area on the rear fender and will gas up from the trunk area. Will a 39/40 ford work? Not sure and installing parellel leaf in the rear instead of the orig, what can I use and what's a good soure. Any help or direction appreicated, Thanks. Ken
I don't know how simillir they are, but we used a tank from a 68 mustang on my brother -n-laws 46 Ford coupe. All we did was measure the area where the tank was to sit, went to the junk yard and started measuring.
Recently someone mentioned a certain JEEP gas tank that was almost a direct replacement, for I THINK a 40 ford? FONZI
Hmm, sounds good. so everything pretty much falls into pace, straps and all. what's the going price for one and are there any "do this befor.." kinda thing? Thanks fellas, also, repops are to damn expensive...Ken
I would think a 39-40 Ford would work. I have a 36 Ford tank in my 40 Ford, the only difference is the filler bung hole (he said bung hole....huh huh huh) is at an angle where a 40 Ford is straight. If you arent going to fill through the fender, that wont matter.
