Complete running Ford Flathead motor. Pulled out of a '46 Ford Truck Comes with everything you need to get up and running in your vehicle - Offenhauser heads & intake - Holley 4bbl carb 600cfm - high volume water pumps - Headman exhaust headers -aluminum radiator and hoses - motor mounts - A/C bracket and compressor if needed Also have a 5 speed Tremec and bellhousing that can go with this motor (it is being listed separately) Only reason it came out is because the owner wanted to go with a crate motor for bigger power. Located in Charleston, SC It is currently in the container that the crate motor came in so it would be easy to load into your truck or trailer. $2900 or best offer
