Compression fitting for Stromberg 97s fuel inlet
Discussion in 'The Hokey Ass Message Board' started by HotRodMicky, Jul 16, 2006.
  1. HotRodMicky
    HotRodMicky
    Hi, where could i get (online) the compression rings for the fittings on 97 and 94
    carbs for 1/4 line??? I have the stock fittings...jus need the "rings", but would buy complete
    I want make the fuel lines on my 2x2 setup with hard 1/4 line.No rubber.
    What else are they used for?Where could i get them (Home Deopt?)
    I'm from Germany , so i can't walk in the next Hardware store in the US ;-)
    TIA
    Michael
  2. curtiswyant
    curtiswyant
    Napa carries them, p/n 59x4. I can buy them all day long, how many do you need? PM me and I can probably send you some for shipping cost :cool:
  3. Enbloc
    Enbloc
    from London, UK
    They are the same as whats used on the stock Model 'A' up-drafts.
    Is there a Model 'A' supplier in germany?
  4. HotRodMicky
    HotRodMicky
    Thanks for the replies.
    I don't like them "A" Suppliers ower here ...but will try.
    curtiswyant i'll send you a PM .
    Thanks
    Michael
  5. Bruce Lancaster
    Bruce Lancaster
    Yeah, I have a 1938 Weatherhead catalog, and that number hasn't changed...
    I don't know if my present stash is Weatherhead or not; I've seen the things made two ways...one with the fitting and the compression ring made as separate parts, one with the two together but made as break-away so they separate during the tightening down.
    The fittings are Ford only, the rings are general hardware items. Repro restoration shop fuel lines are as good a source as any for the fittings.
    My recipe for carb hardlines: Get parts store 1/4" brakelines, brake line T fittings, and a bunch of Ford fittings. ***emble three hardlines into the T, bend to fit (often the rear carb line is a short straight piece), cut off lines to needed length at carbs and pump, slip on Ford fittings.
  6. HotRodMicky
    HotRodMicky
    Hi,
    i couldn't find the number online.......at Napa.
    Thanks for all the replies!!
    Bruce this is what i want to do.
    Michael
  7. Bruce Lancaster
    Bruce Lancaster
    Try Sacramento Vintage Ford--I think I got mine (set with fitting and loose compression ring) from them. NAPA online is very limited, especially with odd older stuff, even though they still have the parts. Also try searching Weatherhead fittings online--you may find a place that does orders online. If any problems, I can send you a few. You also likely need to order some finished 1/4" brakelines and 1/4" brake T fittings as raw materials, I think, and I believe I got those from Sacramento too, just bvecause online was easier than dealing with the local NAPA.
