Technical Compression problem
Discussion in 'Traditional Hot Rods' started by old trucke, Jul 12, 2024.
  1. old trucke
    old trucke
    from ohio
  2. old trucke
    old trucke
    from ohio
    I've purchased an leak down gauge. Left head is still on,(driver side) . Attached leak down gauge , air leak coming from intake port on head.i am going to other head back on and leak test. Thanks trucke
  3. X-cpe
    X-cpe
    If you have a dual plane intake, the commonality between #5 and #8 is the intake runner. The pistons in those two cylinders travel in the same direction at the same time, but on different strokes and fire 360* apart from each other. With no compression on #8 and low compression on #5, I believe you will find the primary problem on #8 which is then affecting #5.
    tractorguy likes this.
  4. TA DAD
    TA DAD
    from NC
    that is with the rocker arms loose.valve closed ?
