Technical Compression Ratio
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Jun 25, 2024.
  1. seb fontana
    seb fontana
    from ct
    If an engine has an 8:1 compression ratio and you want to increase stroke by .250, all else staying the same where will the compression ratio go to? My computations say not to much increase, like only to about 8.7:1. I don't think thats right?
    Sharpone likes this.
  2. Budget36
    Budget36
    I was thinking of a 383 va a 350. At near zero deck with flat top pistons and 72 cc heads, 350 (well .030 over) was around 9.5-1, 383 was around 10.7 as I recall.
    Only change was basically .252 stroke increase.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Need all the numbers (bore, stroke, piston dome or relief, head camber size, head gasket volume) other wise we’re all guessing.
    Deuces, lumpy 63, Mr48chev and 2 others like this.
  4. deuce1932
    deuce1932
    from Australia
    "increase the stroke by .250.. all else staying the same.. "
    Ha ... there won't be any compression.. as the heads won't bolt on.
    Increasing stroke requires a reduction in rod length or piston pin height to compensate for the increased stroke.
    We're ******* in the wind without some more information. :)
    Deuces, 2OLD2FAST, JD Miller and 2 others like this.
  5. 67drake
    67drake
    from Muscoda WI
  6. squirrel
    8.7 sounds about right to me
    Desoto291Hemi likes this.
  7. Fordors
    Fordors
    I threw some numbers together for a flat top piston 350, zero deck, .042 gasket and 68 cc heads and it came out to 10.3-1. With that 1/4” stroke increase and everything remaining the same it came out to 10.96.
    @squirrel is right on the money.
    seb fontana and gimpyshotrods like this.
  8. Dave G in Gansevoort
    from Upstate NY
    You can approximate the increase by making a couple of ***umptions about the volumes required to calculate compression ratio.
    1st: ***ume the volume at tdc is constant, i.e. pistons have the same dome, the combustion chamber is unchanged and either the rod length or the compression height is changed to get the same volume when the pistons are at tdc.
    2nd: let's use a 302 and a 327 Chevy as examples. The swept volume of the 302 is 37.7 in^3 and the swept volume of the 327 is 40.8 in^3 per cylinder. We're going to ***ume that the piston is sealed right at the top of the piston so no crevice volumes to get in the way of ease of calculations.
    Finally compression ratio is the volume at tdc divided by volume at bdc. Volume at bdc is the swept volume of the cylinder and the volume at tdc. Or
    Vtdc/(Vbdc+Vtdc)=cr We can write in the cr as 1/8 giving
    Vtdc/(Vbdc+Vtdc)=1/8 rearranging gives
    Vtdc= 1/8(Vbdc+Vtdc)=1/8Vbdc+1/8Vtdc
    Collecting terms Vtdc-1/8Vtdc=1/8Vbdc
    And 7/8Vtdc=1/8Vbdc
    Or 7Vtdc=Vbdc
    We have Vbdc=37.7 for the swept volume of a 302. Therefore Vtdc=37.7/7=5.386 in^3
    Now using that in the original equation and the swept volume of a 327 cylinder we get
    5.386/(40.8+5.386)=0.117
    Which is: cr=8.57:1
    So just a little bit over a half point increase in the compression ratio. APPROXIMATELY
    And I really nerded out there. Sorry, the engineer in me escaped tonight...
    I promise not to do it again.
    Well, at least not for a while...
    Yup you guys got there a lot faster than me...
    Deuces, 38Chevy454 and Just Gary like this.
  9. 05snopro440
    05snopro440
  10. Dave G in Gansevoort
    from Upstate NY
  11. squirrel
    welcome to the modern age.
    When I took geometry in high school in the mid 70s, our teacher showed us how to use a slide rule....and said don't worry, you'll never have to use one, because calculators exist now.
    I think the same thing applies to anything that has an equation now, you can find a bunch of online calculators that will replace all the required math
  12. Sharpone
    Sharpone
    Dave do you still remember how to use your slide rule? I took mine out of the desk drawer a few month ago thought about playing with it, put it back in drawer and haven’t thought about until now. Ingenious devices!
    Dan
  13. 05snopro440
    05snopro440
    As an engineer I like to do math like this by hand on occasion, probably to prove to myself I still can. But the calculators make it super easy to compare.
    Deuces, rod1 and Sharpone like this.
  14. Marty Strode
    Marty Strode
    What, didn't you have an abbacus ?
  15. Dave G in Gansevoort
    from Upstate NY
    As a matter of fact, yes, my brother and I had one as kids. We had an aunt who was a missionary nun/doctor who was stationed in Taiwan. She sent us one for Christmas when I was about 4. Never did get the hang of it.
  16. 1/2 stroke= .125. PI r squared times .125 and divided by the metric conversion to cc's. Add that to the current deck volume at tdc and you'll have a very close number. Current cubic inches divided by 8. One cylinder volume divided by 8 should give volume at tdc. That would be close.
  17. Sharpone
    Sharpone
    125. PI r squared
    I thought pies are round.
    I had to go there :rolleyes:
    Dave G in Gansevoort likes this.
  18. Dave G in Gansevoort
    from Upstate NY
    It's a dirty job, but someone needs to do it...
    seb fontana and Sharpone like this.
  19. JD Miller
    JD Miller
    :D exactly, pistons will be above the block deck and the rings will fly off :eek::D
  20. snoc653
    snoc653
    from Iowa
    As mentioned, if you increase the stroke .250, you will need to change crank, pistons, rods, or all three. No engine has the piston .250 down in the hole at TDC. So if the the only change is stroke, it will push the piston above the deck at TDC. Adding .250 to the crank stroke, requires figuring out the pin height on the pistons to be used, the rod length, and how far in the hole that will leave the piston at TDC. The size of the bore also affects how much compression gain you will get by adding the .250 to the stroke. In other words, it is very doubtful that the only thing that will change is the stroke. Once you have all the numbers there are a mul***ude of compression calculators online. Plug them in and see where you end up.
    If you want to do the math by hand you can do that as well. Or use a slide rule, calculator or somewhere in between they even made manual and electric adding machines (not to be confused with a calculator)
    69fury and Sharpone like this.
  21. 55blacktie
    55blacktie
    UEM Pistons has a good online CR calculator for both static and dynamic, but you'll need to know your numbers; guessing won't get the job done. If calculating DCR, and you have a solid cam, don't use intake closing @ .050 + 15 degrees. Use intake closing at .020 (advertised for solid cam).
  22. seb fontana
    seb fontana
    from ct
    Thanks to the guys that read my post and answered the simple and not gone of the edge. Depending on bore and stroke in the combinations I tried it came out less than 1.0 increase. I had expected more but it suits my initial combination thoughts. Thanks to those that ciphered.
  23. Ericnova72
    Ericnova72
    from Michigan
    Some of those 1970's 400 and 440 Mopar B and RB came darn close though.
    Bet you could do it with a slight trim to the dish top. LOL
    Old John Deere B 2-hole thumper could for sure.:D
  24. Ericnova72
    Ericnova72
    from Michigan
    If you are talking 350 vs 383 SBC, you are exactly right, the difference is 7/10ths of a point.
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    With additional engine specs, your answer is in here.
  26. Beanscoot
    Beanscoot
    Nifty! Is that still sold?
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
