Technical Compression / TDC Questions
Discussion in 'Traditional Hot Rods' started by coop46, Dec 29, 2023.
  1. Jimmy Brandon
    Jimmy Brandon
    You got a lot of good info. But to evaluate an engine that does not have a starter hooked to it, you need to use a cylinder leak down tester. Better info than a compression tester in my opinion anyway. You rotate each cylinder to TDC valves closed and pressurize the cylinder tool measures how much air leaks off. When I build an engine, I leak it on the stand before installing just to check my work.
    Toms Dogs likes this.
  2. Toms Dogs
    Toms Dogs
    from NJ
