compression test?
Discussion in 'The Hokey Ass Message Board' started by silent rick, Jan 6, 2008.
  1. silent rick
    silent rick
    how do you guys run a compression test on your hemis? does anyone offer an adapter or extension to attach your gauge to or do you guys sacrifice a plug and weld a piece of pipe to make your own?
  2. squirrel
    get a real compression tester, they have a long hose that screws into the plug hole.
  3. silent rick
    silent rick
    how do you remove the hose from the plug adapter? long needle nose pliers?
  4. squirrel
    I'm not sure what you mean....?
  5. troll
    troll
    from verona va
    Screw the adapter onto the hose tightly and then screw the ***embly in the plug hole by gripping the upper end of the hose. Do not screw it in very tight- the o-ring seal does not require much torque to seat it against the head.
    Troll
