Technical Compressor not putting out
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jan 29, 2025.
  1. johnfin
    johnfin
    from Florida
    My big boy has issues. Pumps up to over 120psi but nothing out of the hose. Is it possible the hose is plugged? Its a short hose and not kinked.
    325w likes this.
  2. squirrel
    the ball valve (blue handle on the right side plumbing) is closed.
  3. SS327
    SS327
    Open the valve.
    Moriarity likes this.
  4. johnfin
    johnfin
    from Florida
    I shut it off to pull the hose off. I need to try another hose. Never had a bad or plugged hose.
  5. squirrel
    it can happen.
    Disconnect the hose, open the valve, should work, eh?
    Also check the quick disconnect fitting, if it has one.
  6. johnfin
    johnfin
    from Florida
    Air did come out but it did with the hose, just not with force. I will try a new hose but i have had issues in the past with the regulator, hence the question.
  7. NoRust
    NoRust
    Sounds like your compressed air is lazy, Yes, you have lazy, non motivated air. :mad:
    dogwalkin and '34 Ratrod like this.
  8. squirrel
    There doesn't appear to be a regulator on the compressor. There is a pressure switch, that turns the motor on and off, but you can watch the gauge to see when it starts and stops, and if the pressures are correct.
    Mr48chev likes this.
  9. oldsmobum
    oldsmobum
    from SoCal
    I have seen hoses fail like this. They delaminate on the inside, and a flap of rubber seals the inside of the hose with infuriating efficiency like a check valve.
    squirrel likes this.
  10. Budget36
    Budget36
    Unscrew the fitting from the valve, fill the tank, open the fitting. Air? Then fitting (quick connects can fail) or the hose, or end with quick connect on the hose.
    oldsmobum likes this.
  11. Pass The Torch
    Pass The Torch
    Dated a girl like that once; she got replaced….
  12. wheeltramp brian
    wheeltramp brian
    I get a lot of water condensation in the fittings and have to replace them every 6 months or so. They clog up the ports.
  13. 14 hours. Way longer than I expected. LOL
    Ben
  14. johnfin
    johnfin
    from Florida
    You guys were right, hose was junk, it delaminated. I put godzilla hose on to try it out.
