Technical Compressor oil level?
Discussion in 'The Hokey Ass Message Board' started by 34Larry, Mar 20, 2020.
  1. 34Larry
    34Larry
    You might recall my inquiring about air compressors a week back or so. I found a replacement motor, have it installed and now a confession about the oil. I have no idea and never have had how to gauge and keep the proper level in it. I have just kept it visible when opening the port plug and called that good. This is a older 60 gal upright Campbell Hausfeld no sight gl*** or much of anything to gauge what is in the thing.:confused::eek::rolleyes:
  2. Budget36
    Budget36
    Maybe search for a manual for it online? Then drain and refill to proper amount. Once done maybe you can fashion a dip stick for the future to check it.
    2OLD2FAST likes this.
  3. noboD
    noboD
    Contact the manufacturer with make and model number, maybe serial too. They will send you a manual.
  4. lostone
    lostone
    from kansas
    Agreed, should be able to find a manual.
    Some of the old ones had a slot in the threads in the oil fill and you just made sure the oil was at the top of the slot.
    flatford39 and 2OLD2FAST like this.
  5. winduptoy
    winduptoy
    How many years did it run with you monitoring and maintaining the oil level the way you have in the past? It was the drive motor that ****ped out, not the compressor. I bet visible, up in the fill port is good. Here is a link to compressor oil at Home Depot....https://www.homedepot.com/p/Campbell-Hausfeld-Gallon-Compressor-Oil-ST126701AV
    I hope it works...the link that is and if it doesn't it is non detergent 30 weight....ISO 100 oil which is what I would have guessed
    Good luck there buddy
    Desoto291Hemi likes this.
  6. 34Larry
    34Larry
    Thanks guys for the advise, I'll follow it.
  7. tb33anda3rd
    tb33anda3rd
    mine has a sight gl***, but when the oil level is at the line in the sight gl*** the oil level is to the top of the visible port, looking into the fill plug hole.
  8. tb33anda3rd
    tb33anda3rd
  9. walter
    walter
    I bought mine new and took it home and put oil in it and did't pay any attention to the directions on breaking it in. Turned it on and went to work. It never pumped very well. I used it for about 3 years and never checked the oil until it locked up. I put a new replacement compressor and actually read the instructions for oil and break in. Compressor works great and I watch the oil level as well as change it every year.
    winduptoy and Bandit Billy like this.
  10. 41rodderz
    41rodderz
    from Oregon
    Bet your wife doesn’t let you live that down . :D
    walter and Bandit Billy like this.
  11. Bandit Billy
    Bandit Billy
    That's the kind of stuff I never admit to! You're a better man than I Gunga Din!
  12. DDDenny
    Make sure to use the correct (air compressor) oil for your unit.
    From my C/H manual, compressor was bought in late 80's.
  13. tb33anda3rd
    tb33anda3rd
    ^ your low on oil.
  14. DDDenny
    And air too!
    mgtstumpy likes this.
  15. mgtstumpy
    mgtstumpy
