Technical Compressor Oil Question
Discussion in 'The Hokey Ass Message Board' started by Al T, Mar 29, 2020.
  1. I’ve got an old DeVilbiss upright compressor in my shop and it calls for 20 weight engine oil. Doing a little research online it seems that the consensus is 10W30 is the closest match performance/specification wise to 20 weight engine oil. Before I add some 10W30 to the case, does this sound right?
    Thanks in advance.
    Allan
  2. Inked Monkey
    Inked Monkey
    Wouldn't you want non detergent as the compressor does not have a filter?
  3. Inked Monkey
    Inked Monkey
    You can get straight weight oils at farm stores and Oriellys
  4. uncle buck
    uncle buck
    You can also buy compressor specific oil. NAPA sells it as NAC # 82-6020 although it is advertised as 30wt
    I believe Sta-Lube makes a compressor oil too
  5. Jmountainjr
    Jmountainjr
    Yes, non-detergent 20wt is what you are looking for. Older compressors usually wanted 20 or 30wt non-detergent oil depending on ambient temperature. Newer ones usually use a synthetic compressor oil.
  6. Tri-power37
    Tri-power37
    Non detergent 30 w is all I’ve ever used in older compressors and it has helped my compressors last for a lot longer than they should have. It seems like Castrol is what I always find on the shelf , although I have no preference. I change it when it looses its golden colour.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    Good question and use 30 wt non detergent oil.
  8. bill gruendeman
    bill gruendeman
    I used regular 10w30 for years with no problems. Then I toured the amsoil plant and switched to amsoil compressor oil now the compressor sounds better ( quieter) .
    oldiron 440 likes this.
  9. oldiron 440
    oldiron 440
    I switched to the Amsoil synthetic oil in my compressors ten years ago.........
