Con Rod sizes
Discussion in 'The Hokey Ass Message Board' started by jelp, Nov 21, 2012.
  1. jelp
    jelp
    from australia
    I am trying to find con rods 7.25 inches long to fit a 2.25 crankshaft and an inch wide at the big end the wrist pin size is not important. Thanks in advance
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Did a little searching in my Connecting Rod Manual and the Clevite catalog.
    I couldn't find a match to your specs. I've done quite a bit of cross matching in the past.
    Maybe if you tell us what you've got and what your trying to do we can help you narrow down your search,
  3. 73RR
    73RR
  4. raengines
    raengines
    from pa.
    find an available rod you can get a custom piston made for is an easier way to go, moving pin location isn't that hard
  5. moonman29
    moonman29
    Eagle rods has a 7.1" rod for stroker assemblies for mopar big blocks. I'm not sure about the other dimensions that you need but it's a start. What application do you need it for. Gives us some more info and maybe we can help some more.
  6. CNC-Dude
    CNC-Dude
    Scat and Eagle both have rods to fit the Big Block Chevy that are 1.000" wide, 2.200" journal but are 7.100", thats as close as you are going to get for an off the shelf rod to suit your needs.
  7. Captain Chaos
    Captain Chaos
    from Missery
    sounds like pro stock size .
    you may be able to buy the off shelf cat rod and re-size it, open big end to 2.25 from the 2.200 and use an offset bushing on small end w smaller pin size than BBC to get the extra .15"
    But if you have to get custom made pistons, the slight difference can be made up by moving pin location
  8. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
