Technical Con Rod substitution.
Discussion in 'Traditional Hot Rods' started by Outback, Apr 11, 2023.
  1. Outback
    Outback
    from NE Vic, Oz
    TBH I don't even know if building this engine - & putting it in a T is even a good idea, It's a nice engine compared to the Fords, has everything we want except the CI's anyway will keep pondering & thinking about boxing some rods!
    winduptoy likes this.
  2. Kevin Pharis
    Kevin Pharis
    from Califunny
    Sounds like a good excuse to supercharge it:p
    Outback, winduptoy and RICH B like this.
  3. winduptoy
    winduptoy
    Outback and guthriesmith like this.
  4. oldolds
    oldolds
    Just make what you need? You only need a bit of metal, 2 hole saws and a hacksaw to cut it into shape!o_O:eek:
    Outback likes this.
  5. Outback
    Outback
    from NE Vic, Oz
    perfect! we have some 4330 bar stock kicking around....
  6. Outback
    Outback
    from NE Vic, Oz
    now you are talking!
  7. Beanscoot
    Beanscoot
    Look like Schraders, not Prestas.
    So now it's obvious what the purpose is.
  8. SR100
    SR100
    I’m missing something. Please explain it for me.
    Budget36 likes this.
  9. Beanscoot
    Beanscoot
    Too big for Presta, the right size for Schrader.
  10. Budget36
    Budget36
    So, what is the purpose of them?
  11. chopolds
    chopolds
    from howell, nj
    It's obvious! It makes the engine a variable compression engine. By putting more air pressure into the rid, it moves the piston higher up into the bore, and increases compression, making MORE power! Genius idea!
    Outback likes this.
  12. Outback
    Outback
    from NE Vic, Oz
    :p:eek:
  13. oldolds
    oldolds
    You fill them with helium to make them lighter
  14. Budget36
    Budget36
    But if the rods became lighter, there goes the balance on the ***embly!
    SS327 likes this.
  15. Outback
    Outback
    from NE Vic, Oz
    While I have sold this project on to a restorer I will leave this info here so it can be found later.
    Perkins A3.152 or AD4.203 engine series.
    • The Dimensions: These m***-produced, heavy-duty forged steel rods feature an off-t******lf center-to-center length of 9.000" or 9.500" (depending on the exact Perkins variant) and feature a 2.000" big-end bore.
    AccurateMike likes this.
  16. mkubacak
    mkubacak
    No, no, no. If you use Helium, it is a noble gas, therefore it is so uppity it will self balance.
    Outback likes this.
