condensers
Discussion in 'The Antiquated' started by mikespeed35, Oct 6, 2018.
  1. mikespeed35
    mikespeed35
    from MI.
    Someone on another forum said they read on H.A.M.B. that there are 6V and 12V ignition condensers. Would someone like to speak to that. I didn't think the condensers cared?
    CORDiallyMike
  2. sevenhills1952
    sevenhills1952
    Condenser is a capacitor.
    In automotive cl*** in 70s I remember the one teacher saying if the negative points contact is negative material then you're negative capacitance.
    So on a negative ground vehicle the points body is ground (negative). If that contact after use has a pit and the moving contact has a "point" then it needs more capacitance. Random ones I've checked over the years vary in capacitance, (maybe from .33 to .47ufd from memory).
    6v or 12v the condenser will work.
