I worked on my seat a little more today and beefed it up a little. It's alot more rigid, all thats left is to install some mounting tabs,secure the wood to the frame and add some foam and material. Let me know what you guys think
Kool man, One thing I might have done different is mount the wood for the seat back on the back side of the tubing. I think it might make doing the upholstery easier. Just my point of view not a knock. I like em! The Wizzard
One more thing. What do you think of taking a piece of conduit and slicing it open and put it on the edge of the gussett.That would give the upholstery a rounded edge instead of the sharp edge that might make the fabric wear through faster. The Wizzard
give the conduit a little radius and slit it to fit over the gusset. make a tab for the plywood to mount to. paint the frames a diffrent color then the upholstery
[ QUOTE ] One more thing. What do you think of taking a piece of conduit and slicing it open and put it on the edge of the gussett.That would give the upholstery a rounded edge instead of the sharp edge that might make the fabric wear through faster. The Wizzard [/ QUOTE ] I thought about that but since the gusset is welded to the outside of the frame I thought it would look wierd. i was thinking about some rubber fuel line or something on that order
Well, I'd post pics of mine but I don't have any. You've seen 'em anyway. Your seats are looking really good. I gotta make my way up there sometime to check that thing out.
If you slit the tubing and roll it to the inside it shouldn't hang out past the gussett. Maybe just lay it on the inside like the rest of the frame work. Just a sugjestion. The Wizzard
I think that looks great. How thick will the foam be? Your backside may bottom out on the wood occasionally, making for a sore tailbone. How about cutting a hole in the plywood, and covering it with nylon webbing or canvas or duck cloth or something that has a little give? --Matt
Duece, That webbing idea sounds good. Thanks for the imput guys. I'm working on a folding p***. seat tonight. I'll post pics later. ......Mike
