Technical Confused sbc head question
Discussion in 'The Hokey Ass Message Board' started by olds vroom, Jan 19, 2021.
  1. olds vroom
    olds vroom
    I have a 305 pulled from an 86 Chevy truck . I’ve been running this engine for 5 years with no major issues but have decided to do a rebuild as it has almost 200000 on it . Going through what I have the casting numbers on my heads are 3998993 and 3998997 my research shows these are 350 heads but I’ve found some that say they were used as low power heads on trucks in the mid 80s can anyone verify this ? My rebuild kit will be here tomorrow and I only have a limited time to put this back together. Thank you
  2. Budget36
    Budget36
    No input other than with two different casting numbers, leads me to think someone has had their hands on the engine before
    Next thought, if running good and no issues, why take it apart?
  3. lippy
    lippy
    from Ks
    I get,
    3998993 is a 68-76 350 truck head, 1.72 intake valve.
    3998997 is a 1972 400 1.94 intake valve. Lippy
    mad mikey likes this.
  4. olds vroom
    olds vroom
    It was starting to burn oil and smoke and rear main seal started to leak.
    Deuces likes this.
  5. olds vroom
    olds vroom
    Both heads I have are 1.94 intake valves
    Deuces likes this.
  6. lippy
    lippy
    from Ks
    Did you read the numbers right? Just asking. Lippy
    Deuces, mad mikey and Budget36 like this.
  7. olds vroom
    olds vroom
    Deuces likes this.
  8. Flathead Dave
    Flathead Dave
    from So. Cal.
    Some Ford and chevy motors had interchangeable parts but not ford interchanging with gm.
    egads and warhorseracing like this.
  9. Budget36
    Budget36
    I’ve only taken apart 5 or 6 SBCs that I knew the history of, last to mid 80’s up, but all had the same head numbers. I guess GM could have put on something that was the same, I’ve just not seen it
    Flathead Dave likes this.
  10. Wrench97
    Wrench97
    3998993 307/350 68-79 1.94/1.50 76cc
    3998997 350/400 71-73 1.94/1.50 76cc
    I'd say somebody put a set of rebuilt heads on that motor sometime in the past.
    Most 400's I've seen had extra cooling holes drilled in the web between the cylinders.
    mad mikey and Deuces like this.
  11. lippy
    lippy
    from Ks
    I was going to ask for a pic of the other sides. All 400's had steam holes as they are siamesed cyls. I'm still getting 997 is a 400 head. You can run 400's on a 305-350 but not the other way around unless you drill the steam holes in them. Lippy
    j-jock, Deuces and mad mikey like this.
  12. mad mikey
    mad mikey
    400 SBC heads have what is called steam holes. Lippy beat me to it.:)
    Deuces and lippy like this.
  13. olds vroom
    olds vroom
    But why would anyone put 350 heads on a 305?
    Deuces likes this.
  14. lippy
    lippy
    from Ks
    Never saw a 307 with 1.94 intakes lol 350-400 heads on a 305 yes.
  15. lippy
    lippy
    from Ks
    I would say the normal rebuild shop would just put any head that would fit nowadays. Then when it ran lazy they would say, just the way it is. lol
    warhorseracing, Deuces and mad mikey like this.
  16. Wrench97
    Wrench97
    Bigger valves, some rebuilders pushed 350 heads as standard so less part#'s to stock.
    Deuces, lippy and mad mikey like this.
  17. lippy
    lippy
    from Ks
    Until they put 350 heads on a 400, lol Lippy
    Mr48chev, Deuces and Wrench97 like this.
  18. Wrench97
    Wrench97
    It can be done, all you have to do is drill the holes.
    At one time 400 head cores brought a premium price....................
  19. lippy
    lippy
    from Ks
    I meant till the un knowing shop didn't drill the holes and sent it out. Lippy
  20. olds vroom
    olds vroom
    So other than the loss of compression is there any other draw backs to using these heads on a 305?
  21. Wrench97
    Wrench97
    Were you happy with how it ran before?
    What pistons are in that engine flat top or dish?
    In the past I've put used heads off 350's on 283's, 305's, 307's and 327's simply because I had them and it made the car/truck run again I can't say there were any adverse effects, of course these were not running times at the drag strip just solid running engines.
    mad mikey, Deuces and lippy like this.
  22. olds vroom
    olds vroom
    It ran fine but I did notice a little less power at the end of last year.I’m not one of those guys that has to spin the tires everywhere I go or drag race every light this is just my fun cruising car and I do drive it every chance I get ( weather permitting) . So I’m just looking for good and reliable not balls to the wall power after all it’s just a 305.
  23. TCATTC
    TCATTC
    That's enough
  24. Flathead Dave
    Flathead Dave
    from So. Cal.
    For instance. had a 305 with 350 heads in my Camaro. Bought it that was and had no problems.
    Also had a 289 with 302 parts in my Pinto.
  25. Paint_Rep
    Paint_Rep
  26. lippy
    lippy
    from Ks
    Then the loss of power may have been it just was time to freshen her up. You should be fine. Only you know what you need, we just try to answer questions in the best way we can. We always banter back and forth between us. That is how we share info. LOL. I just hope we helped in some small way. :D
  27. swade41
    swade41
    from Buffalo,NY
    The 416 and 601 305HO heads are the heads you need for that engine and are not that expensive, they offer a smaller cc and would wake your engine up as compared to those 350 and 400 heads you have now.
  28. olds vroom
    olds vroom
    Thank you for the input. While I’m disappointed these are 350 heads . They are what I have and know they are good functioning heads. So most likely I will reuse them.
  29. arkiehotrods
    arkiehotrods
    3998993 307/350 68-79 1.71/1.50 1.94/1.50 76cc
