Connecting 2 barrel 1960 Olds carb
Discussion in 'The Hokey Ass Message Board' started by Dyna88Kid, Aug 12, 2013.
  1. Dyna88Kid
    Dyna88Kid
    I need some help with the connections to my carb. If anyone has some pictures of a connected one, that'd be great. I know there's a few fuel lines but isn't there also some smaller lines to attach?
    Any help is much appreciated!
    GO OLDS '60!!!
    the most comfortable ride you ever tried!
  2. Dyna88Kid
    Dyna88Kid
    Bump! I'm doing this tomorrow!
    GO OLDS '60!!!
  3. 2racer
    2racer
    search google images for: 1960 Olds carb vacuum diagram
  4. Dyna88Kid
    Dyna88Kid
    Well, didn't find much with that. For some reason, olds owners just don't photograph stuff!
    GO OLDS '60!!!
  5. Well, I guess you could be the first then :rolleyes:
    Post up a photo of yours and then we can walk you through it.
  6. 2racer
    2racer
  7. Dyna88Kid
    Dyna88Kid
    Ok, this might be easier than I thought.
    There's three things to be connected, the front fuel line that goes into the float chamber, the big fuel line in the rear, and a smaller vac*** line.
    I still have no idea where the vac*** line goes.
    GO OLDS '60!!!
  8. Saxman
    Saxman
    There should only be one fuel line. It's hard to tell with out pics but I suspect your "big fuel line in the rear" is for your PCV. Small vacuum line probably goes to the vacuum advance on your distributor. Post up some pics and it will be easier to help you.
  9. saltflats
    saltflats
    from Missouri
    There is a line from the fuel pump to a fitting in the rear of the carb witch I would beleve to be the vacuume pump side of the fuel pump. The dist hooks to a port on the p*** side of the card say half way up the float bowl between the bowl and the throttle body.
  10. Dyna88Kid
    Dyna88Kid
    Here's the pics... Couldn't get them to upload from the app
  11. Dyna88Kid
    Dyna88Kid
    That's the fuel pump, here's the carb
  12. vtwhead
    vtwhead
    small br*** ****** is for the vacuum to the dist. Looks like you have a kink in your gas line. You should fix that so that you get a good supply of gas all the time. Watch that old 2GC carb as the needle seat may be stuck if it has been setting for a long time. When you start that make sure that the gas is not flowing out of it becasue of a stuck seat.
  13. Motors Auto Repair Manual
    Factory Shop Manual
  14. 54nomore
    54nomore
    from illinois
    I'm guessing that a '60 Olds doesn't have a pcv but rather a road draft system.
    The large ****** in back maybe goes to the power brake booster:confused:
    Also: what rustynewyorker said:D
  15. partsdawg
    partsdawg
    from Minnesota
  16. Dyna88Kid
    Dyna88Kid
    I don't know where I'd find the "power brake booster"
    I've tried to get the manuals, but it's a lot easier said then done, especially when you're 17 and don't have a credit card.
    GO OLDS '60!!!
  17. ebay....
    And old Motors and Chiltons manuals are everywhere, car show swap meets, flea markets, used book stores...
  18. 2racer
    2racer
  19. 2racer
    2racer
    power brake booster is the round metal thing on the firewall that the master cylinder bolts to, just to the right and below the wiper motor, a big vacuum line goes to this from the back of the carb base
  20. jakespeed63
    jakespeed63
    Sorry Charlie, I have the factory 1960 Olds service manual, and no detailed pics of carb on engine. :confused: Comprehensive rebuild and specification section, but no pics, other than carb on a mounting bracket.
    JT
  21. Dyna88Kid
    Dyna88Kid
    I don't think so...
    Brake lines > circle roundy thing.
    GO OLDS '60!!!
  22. Dyna88Kid
    Dyna88Kid
    See...
  23. Dyna88Kid
    Dyna88Kid
    Nevermind, I don't know why I doubt you all.
    One day I'll learn
    GO OLDS '60!!!
  24. Paul
    Paul
    Editor
    hope you never stop, learning that is
  25. Dyna88Kid
    Dyna88Kid
    Well, she's all connected, but now I have to take the fuel tank apart again :/
    When I cleaned it the first time, there was, what I can only call a filter, on the end of the inlet inside the tank. I couldn't buy a replacement, so I left it off and put an extra in-line filter.
    I forgot, however, that the extra length on the inlet given by the "filter" was gone too, which means that I can only use about the last 1/3 of the tank.
    GO OLDS '60!!!
