Technical Connecting new side engine panels. 1936 Plymouth
Discussion in 'Traditional Hot Rods' started by Maintain, Jun 26, 2021.
  1. Maintain
    Maintain
    Coupe has a 3 panel engine cowl cover. Just have to top on now. When I try to instal the side panels, there is nothing for the two latches to grab onto! Just a square cut out at each position. Am I missing parts, or installing wrong? Can someone direct me where to find out, or knows themselves? Thank you.
  2. footbrake
    footbrake
    Looks like you're missing part obviously
    Maintain likes this.
  3. earlymopar
    earlymopar
    From memory on a 37', there are 2 U-shaped "catches" per side.
  4. Maintain
    Maintain
    Went thru my box of old parts. Found two newly painted steel brackets that match the existing holes near cowl. Just need to install weatherstripping, and figure out fron portion. Been raining so much here I need sides. Was running just the top piece. Thanks!
  5. Guy Patterson
    Guy Patterson
    yes you are missing the latches. You need to go back to the manufacturer of the system to get the latches. Good luck
