Constant Duty Solenoid
Discussion in 'The Hokey Ass Message Board' started by BIG PORT JIMMY 6, Sep 9, 2005.
  1. BIG PORT JIMMY 6
    BIG PORT JIMMY 6
    I want to build my own remote battery disconect I am looking for leads on an economical source for the solenoid. Any Ideas/ Jay
  2. flamedabone
    flamedabone
    Big Jimmy..
    Tell me more about what you are trying to do. Are you just looking for a battery disconnect switch? One that you can manually turn on and off??
    If so, Summit, Jegs and Speedway have them for about 20 bucks or so..
    I sence, however that you are looking for something more complicated...
    Tell me more, -Abone.
  3. gierhed
    gierhed
    I think you might be wanting a starter solenoid for a Ford maybe, Wells part# F492 or F496. You got any good fenders for an AD truck up there?
  4. Bluto
    Bluto
    J.c.whitney.com :d
  5. A ford type solenoid won't hold up for long if you use it as a continues duty solenoid. I have a Cole Hersee brand that uses silver contacts and heavy duty coil that should work for you. Pm me if I can help. Shaun.
  6. willowbilly3
    willowbilly3
    from Sturgis
    I know Ford used one in their Camper special with the auxillery battery. Have you tried a knowledgable parts store?
  7. enjenjo
    enjenjo
    from swanton oh
    Snow plow solenoid. Or, you can get a Mack truck master disconnect solenoid from a salvage yard.
  8. MP4/8
    MP4/8
    Go to your local napa store. They will have a constant duty solenoid, similar in appearance to a ford starter solenoid, for about $25.
  9. BIG PORT JIMMY 6
    BIG PORT JIMMY 6
    [I sence, however that you are looking for something more complicated...
    Tell me more, -Abone.[/QUOTE]
    Abone,
    Since I plan on using the foot start on my truck I want to use a remotely controlled battery disconnect to make it harder for some doof to hot wire it. i plan on hiding a switch some where to cut it out when I need to. I have been thinking about using a latching solenoid and a sub miniature momentary switch. You could wire up a relay to a led to see the status. Jay
  10. oldcarfart
    oldcarfart
    NAPA auto parts, they are used for snow plow blades, generators, etc. common item.
  11. bulletproof1
    bulletproof1
    from tulsa okla
    try something from a winch ,ramsey-warn.they are made to handle consent on/off use
  12. 4tford
    4tford
    painless wiring site has 2 or 3 different kits for you application.
  13. Ayers Garage
    Ayers Garage
    <hint> My wife's 90 model 5.0L Mustang has one stock....
  14. Indocil Art
    Indocil Art
    Napa all the way just dont use a ford starter selenoid. It wont last. I use them on every thing. You can have an easy to find switch and a hard to find switch to keep some one from driving off with your ride. I use them on every thing even my bikes. Jump the power then just have a ground switch.
  15. mikeyboy
    mikeyboy
    Painless has a continuous duty soleniod part # 40112. Just remember, these draw power when activated, and can run down a battery in a couple of days. They also offer a mechanical latching solenoid kit # 30206. Kinda pricey, but this does not draw any power when activated. You can also get the continous duty soleniods, in a number of configurations at your local Napa
