Contender for the worst MII install ever
Discussion in 'The Hokey Ass Message Board' started by ELpolacko, Dec 26, 2007.
  1. ELpolacko
    ELpolacko
    I belive this is in my top five all time worst installations ever for the IFS of any sort.
    What you are looking at is a Studebaker truck that a customer picked up at an auction. It looked decent on the outside even though a bit "street roddy". Drove like ****, really..
  2. ELpolacko
    ELpolacko
    Doesn't look that bad, right?
    Well what you are looking at is a Speedway crossmember kit for a 35-40 Ford frame. The uprights of the crossmember were hacked off with a torch and attached to what ever they could on the frame. They left the frame as is but added various and ***orted angle and plate to make things sturdy. Then to finish the job they installed the spring towers on backwards. This made for some interesting driving charicteristics and alignment specs.
    It had about a degree of negative caster and two degrees of positive camber. With completly backward anti-dive it made for unusual dips and bobs just driving around in the parking lot!
  3. ELpolacko
    ELpolacko
    Here is what we did to clean things up a bit.
    and then took care of the rear suspension too.
  4. Very nicely done! Is that one of your crossmembers? I thought you were big on the Dodge Dakota IFS.
  5. OGNC
    OGNC
    Looks really nice now Steve...
  6. guiseart
    guiseart
    jeez you do nice work.
  7. VonMoldy
    VonMoldy
    from UTARRGH!
    wow when i saw the first mustang 2 setup i thought if looked pretty ****py. Then seeing how you did it the old setup looks like a pile of puke. Looks really nice wish I could do stuff like that!
  8. DonMan
    DonMan
    Nice work !
  9. ELpolacko
    ELpolacko
    Oh I am, trust me if this truck came in clean I would have talked him into it. Truthfully this is for annother shop in town here. We take on a bit of work like this from time to time.
    The Mustang II is a bit small for this truck. I ended up adding a two inch rack extender to the right side and built custom arms that are 1" longer per side. Not my ideal set up but should be safe and drive a hell of a lot better than when he dropped it off.
  10. Those engine mounts were nice though.....
  11. I thew up a little in my mouth with that first pic.............yeow!
  12. slick64
    slick64
    from Mobile, AL
    I don't know...I think I liked it better before...;)
    Mike
  13. zman
    zman
    from Garner, NC
    very nice... your work and not the original.... I have a '37 Chevy coming into the shop with a messed up MII... I'm trying to figure out the best way to deal with it.
  14. Yo Baby
    Yo Baby
    Is there really such a thing a s a good "M2" ? LOL
  15. Remember me????
    The first pics are why most stock Mustang II installations are a PoS.
    Your installation isn't Mustang II. It's an independent front suspension with about the only thing in common with a MII is the steering gear.
    Your technical knowledge about the suspension design and outstanding fabrication skills makes YOUR suspension installation super.
    Obviously, we both agree on that the stock MII installation looks like a backyard Cob Job by Bubba & Company.
    I've seen a lot worse. At least the steering u-joints were "almost" in phase.
    Those stock bottom MII strut rods mount on the frame in a location that transmits road shock right through to the driver and p***enger feet. How that improves the ride quality leaves me puzzled. More suspension compliance there than in a half dozen of the front ends that you installed.
  16. GMC BUBBA
    GMC BUBBA
    HEY HEY !!
    We would have measured it with a yardstick, marked it with chalk and cut it with a torch!!! And it still would have looked better than that!!!:D:D
  17. ELpolacko
    ELpolacko
    Yeah I remember my sparring partner ;)
    I wish I would have taken some better before pictures of a Cord 810 Sedan we are doing. It came in with a stock Mustang II crossmember grafted into the stock frame and had first generation Nova spindles and brakes installed! The installer leveled out the upper control arm mount and couldn't get anything better than 2 degrees of negative camber!
    You can see the lack of Ackerman by using these spindles.
    http://s206.photobucket.com/albums/bb93/ELpolacko/1936 Cord/
  18. 41woodie
    41woodie
    Well I certainly feel better about what was under my 40 p/u when I bought it. Actually it didn't ride bad at all, and when you consider that the shocks were angled in such a way that the suspension was bottomed against the side of the shock and had rubbed holes in the side of the shock, it was pretty bad. Oh well just rub money on it for awhile and it's all better now.
  19. AZAV8
    AZAV8
    from Tucson, AZ
    Yikes!!!!!!!!!!!
    And the fix is exactly why El Polacko gets to do his magic install of the Dakota IFS on my F1.
    Truck is on jackstands with NO suspension under it, and I'm taking off useless brackets and mounts, filling holes and straightening the whoop-dee-dos in the frame rails. Progress is being made.
    And my daughter gave me a bench grinder for Christmas.
  20. flt-blk
    flt-blk
    from IL
    Looks good Steve, do you charge more to "fix" than do the upgrade in the first place.
    What's the deal with the forward part of the Cord frame, weird??
  21. ELpolacko
    ELpolacko
    Cord's are front wheel drive. That huge bulkhead/crossmember is where the swing arms were attached. If you look close inside the chanel you can still see the large roller/needle bearing for the inside mounting point. The outside bolted to the outer end, sorta-kinda like an IRS Volkswagen or Porsche or Datsun 510.
  22. InDaShop
    InDaShop
    from Houston
    On the 1st pic, I was like WTF? Its going the wrong direction.....WOW!
    And it looks like the motor would have more or less been the structural member keeping the tops of the frame rails from folding in on themselves.
    WOW, fabrication......its not for dummies.
  23. 34toddster
    34toddster
    from Missouri
    Very nice welds on those top hats...Good Job
  24. '52 STVBLT
    '52 STVBLT
    Any pics of the completed install on the Stude?
  25. mazdaslam
    mazdaslam
    Who gives a **** about the crossmsmber install:D(looks awesome by the way)?That adjustable trans crossmember is PURE GENIUS:eek:!!! KICK ***!!!!!
  26. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    That must be one of those overpriced 1500 dollar jobs I was just reading about.:rolleyes:
    Killer work. I love good looking Ch***is work.
  27. Carbs & Chrome
    Carbs & Chrome
    I thought that's how all the cool kids where doin' it now-a-days?!?
  28. Roothawg
    Roothawg
    Wow. What else can I say......
  29. GrantH
    GrantH
    I am 150% sure you were making a smart *** remark about the thread I made earlier. If you knew wtf you were talking about, you would know I thought LABOR wise 1500 was too much, and I personally STILL think it is. So be it, ***** all you want, just remember things can get pretty infected if you don't pull your ******* out every so often.
  30. 38Chevy454
    38Chevy454
    Nice work Steve, I also at forst was like "WTF?" when viewing the original install. Backwards is pretty funny in hindsight, probably was way scary to drive.
