Contest:STUMP SQUIRREL!
Discussion in 'The Hokey Ass Message Board' started by Richard D, Nov 28, 2006.
  1. revkev6
    revkev6
    from ma
    trick question, they came with lug bolts :D
    btw african or european?
  2. squirrel
    I kind of figured....
    here's one for you, how many different lug nuts or bolts are used on a 56 plymouth?
  3. SinisterCustom
    SinisterCustom
  4. revkev6
    revkev6
    from ma
    on the same car or spread over all models;)
  5. Appleseed
    Appleseed
    If I cut 7/12ths of a foot out of my frame, how many inches did I cut out?
  6. Thirdyfivepickup
    Thirdyfivepickup
    Seven?
  7. squirrel
    see, I don't spend enough time in front of the tube....I'm too busy reading books
    the 56 plymouth thing...4...it has left hand threads on the left side of the car, right hand threads on the right side, studs/nuts up front, and bolts on the back. so each corner is different
  8. pitman
    pitman
    OK Prof Squirrel, what is the compliment of Entropy?
    Hint, Bucky came up with this one.
  9. squirrel
  10. revkev6
    revkev6
    from ma
    ahhh I knew the lh rh thing but figured the nut/bolt was a model to model difference
  11. squirrel
    Seven.
    see, I got one right.
  12. squirrel
    both of the ones I had were like that.
  13. rasputin
    rasputin
    from Chicago
    Why are black squirrels so much more bad*** than gray ones?
  14. SinisterCustom
    SinisterCustom
    My buddy's '56 Plymouth wagon has all lugnuts....
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Because of the caste system society has imposed on them.
  16. revkev6
    revkev6
    from ma
    is a 1959 ford ranchero frame the same as a 1959 country squire wagon frame?
  17. Did someone say,"STOMP SQUIRREL"? I LOVE to stomp squirrels and watch their entrails spew out of..........OH! Sorry! Wrong message board.;)
  18. Atrophy?
  19. pitman
    pitman
    Yer close Doc, Bucky said it was Syntropy...or anti-entropy
  20. pitman
    pitman
    Now,
    Should you use a rosebud tip on a gas wrench to remove muffler bearings on a 55 Chev 210?
  21. Thirdyfivepickup
    Thirdyfivepickup
  22. Only when used in conjunction with a 12 pound knockometer.
  23. revkev6
    revkev6
    from ma
    more importantly what is the proper technique for checking the blinker fluid in a 1928 ford roadster :cool:
  24. squirrel
    only on the 150, you gotta use an air chisel on the 210 and an impact on the belair
  25. pitman
    pitman
    As the Bernoulli boys said, upon viewing Newton's solution, "we yield!"
  26. squirrel
    (pretending you're one of my kids for a moment)
    BECAUSE I SAID SO!!!!
  27. pitman
    pitman
    They recognized a superior intellect?
    At least that's my excuse.
    All hail Squirrel!
    I think they saw that his solution to the "catenary problem" was the most elegant, according to legend anyway.
  28. Man, Gramma sure was right about you.....:mad:
  29. I got this one, it is a Garrett T-28, 60 trim 60mm BCI-1 compressor in a T-04B housing.
    CBB
