Contest:STUMP SQUIRREL!
Discussion in 'The Hokey Ass Message Board' started by Richard D, Nov 28, 2006.
  1. Bugman
    Bugman
    Don't tell anyone, but Squirrel is one of my favorite HAMBers(in a manly way, not like how I like CheaterCarl)
    Can Switch Pitch converters be restalled so the "high" range stalls at around 2800?
  2. What normally situated transmission will fit on a GM Quad 4? For a rear drive application?
  3. squirrel
    aw shucks...
    yeah, they can build them kinda however you want. the one in my 55 now has a high stall spec'd at 3000, from PAE
  4. squirrel
    I don't know, I've never looked at the back of a quad 4. it's been 15 years since I had to work on late models much.
    but a wild guess is S-10, they used a couple different 4 bangers in them.
  5. seymour
    seymour
    from PNW
    Holy ****!!! he found them! I spent all night google-ing!
    Solution for the arthritus... take the seeds out! :D okay seriously.... my joints are killing me!
  6. squirrel
    now I feel bad, it only took me about 5 minutes...
  7. Brad54
    Brad54
    from Atl Ga
    Is she Swedish? What's her last name?
    For the arthritis: WD40
    I'm damn glad to know I'm not the only one who has benefited from Dr. Squirrel's wisdom here. And more importantly, I'm not the only one who has noticed it!
    Brad
  8. Actually you were very close but wrong...it is Manual not automatic-
    The three steps are: Lift your foot and step on the rubber pump/bulb on the Left side of floorboard three times:D ...it squirts gear oil from a reservoir in the transmission-thru a series of 1/8" copper lines to each and every moving part of ch***is..the ends of these lines are "laced" to the tie rods,etc, with a leather boot.....
    Baumi likes this.
  9. I'm glad you guys are enjoying yourselves, but I really did expect some tough tech problems to be solved. Oh, well, I still got a kick out of it.:D
  10. squirrel
    oh, I thought it was a "party thread"
  11. No, I try not to start those. Still fun, though.
  12. Model40-770
    Model40-770
    from LOUISIANA
    ok.......read this long time ago and it has stuck with me...... 1979 ford truck, 302, auto, dual exhaust.........new 4-v carb and dualplane intake........a puff of blue smoke comes out of the left tail pipe when taking off from a stop.......at no other time does it do this........
  13. 30roadster
    30roadster
    Ya know...I thruthfully have never see squirrl not have the answer...
    OK - here's one..not tech...
    what chemical that forms a geodesic dome structure is named after bucky?
  14. This one has stumped every one else I have asked. Not really a hot rod question but what the hell, they are my all time favorite car.
    What differed between the first two completed Cobra Daytona Coupes and the last four that made them up to 7mph slower in terminal speed?
  15. Ruiner
    Ruiner
    what chrysler products came with a finned aluminum steering box?
    what stock production motors came with H-beam rods?
    what is your favorite color?
  16. pitman
    pitman
    Similar to the type of food I prefer...Carbon based.:eek:
  17. I guess somebody put studs in my 82.
  18. 30roadster
    30roadster
    true....how many carbons? :D... name that organic compound!
  19. Formula for the speed of a synchronous motor?
    An easy one:
    Chryco V8 from the early 60's - not a Hemi.
    In a Supermarket parking lot, driver would hear a pop under the hood, engine wouldn't start, distributor cap would be askew, but not broken.
    Replace cap, engine started and ran fine until next time around.
    Cause?
  20. RodLand
    RodLand
    Air intake to the ****pit, for driver comfort.
  21. No, but in the right direction......
  22. pitman
    pitman
    This is way too much fun...thanks due to Richard!
    60 Buckminsterfullerine
  23. RodLand
    RodLand
    OK, must have been to the brakes then.:confused:
  24. Oops, guess I led you up the wrong path, it was an aerodynamic issue but it had nothing to do with intakes of any sort.
  25. HotRodDrummer
    HotRodDrummer
    Windshield wiper?
  26. Nope, the last 4 bodies were built in Italy, the first two in the US.....
  27. Ruiner
    Ruiner
    it was the spoiler/air dam, whatever you want to call it...right?
  28. No............
    I knew this one would get'chas!
  29. squirrel
    must be something to do with how nice the perfectly finished Italian bodied cars looked, while the ratty US jobs actually went fast
  30. When the finished cars hit the track Peter Brock and Carrol Shelby were at a loss to explain the difference. It was only worked out after one of the Italian bodied cars was parked next to one of the US built ones.
