Contest:STUMP SQUIRREL!
Discussion in 'The Hokey Ass Message Board' started by Richard D, Nov 28, 2006.
  1. HotRodDrummer
    HotRodDrummer
    Wasn't there a bubble (bump) put in the drivers door top for a tall driver, or was that a dif. car entirely?
  2. Different car, that was the GT40. The bump was made so Dan Gurney would fit in the cars! The Daytona Coupe was built as an 'Interim' car to bridge the gap between the Cobra and the up-coming GT40s.
    You guys give in yet?
  3. squirrel
    I give up, I never paid much attention to those kinds of cars....
  4. HotRodDrummer
    HotRodDrummer
    If squirrel gives up then I guess I do too, hell, I'd hate to have to look it up!haha
  5. breeder
    breeder
    why cant britney find real love???:( :(
  6. squirrel
    I did recall that the ch***is lube system was centralized, but I didn't know how to operate it....unfortunately I'll probably never have the chance to put your instructions to use....
  7. Yeah, a little too off topic realy......
    Something about those cars just seemed to 'get to me'.
    The Italians in all their wisdom decided that the American plans didn't translate into a good looking car so they took it upon themselves to change the windshield rake to a more aesthetically pleasing angle. This took out 4º of rake robbing the cars of a greater terminal speed.
  8. squirrel
    leaking intake gasket? too much oil in the oil bath air cleaner? (now I'm grasping at straws )
  9. squirrel
    that's because I sometimes keep my mouth shut when I don't have the answer :)
    buckyballs, a wierd form of carbon
  10. squirrel
    I think the box in my wife's dart is the one you're talking about...it's a 1970 model. It's a nice looking steering box when it's cleaned up, but now with over 300k miles on it I need to pull it apart and see if I can get the slop out.
    I don't know about the H beam rods.
    my favorite color is blue...no, yellow....no, ARRGGGGGGGGGHHHHH
  11. squirrel
    bad vacuum advance diaphram...or leaking fuel pump....
    but it could be all kinds of other things, we had a 67 plymouth with a 383 when I was a kid, I learned automotive troubleshooting on that car because everything that could go wrong, did! tracked dist cap, oil leaked out of the coil, condenser went bad, funny carb problems, etc.
    synchronous motors? doesn't that have to do with the frequency times the number of poles minus one or something? just guessing, it's been a long time
  12. El Caballo
    El Caballo
    from Houston TX
    The squirrel cannot be stumped, so why bother? I'd rather learn...
  13. OK,,here goes.
    If it takes a one legged chicken 3 minutes and four seconds to hop across a busy highway, how long does it take a three legged gr***hopper to kick all the seeds out of a six inch dill pickle?
  14. squirrel
  15. El Caballo
    El Caballo
    from Houston TX
    See? What brilliance, I would have said purple...
  16. 30roadster
    30roadster
    why it's buckminsterfullerene of course:D ....
  17. Ruiner
    Ruiner
    thanks, now I can start looking for one...Fiddy Four's got one of those boxes, I think he said Tuck gave it to him...I picked it up and played with it last night, and fell in love...'70 Dart...nice...the only problem is, the steering ratio is SLOW!!!...which should be good for bonneville :O
  18. I am using the same box for cowl steering, will a longer arm make the steering quicker?
  19. pitman
    pitman
    Hmmm...does a bear pee in the____?
    Oppps! Does the Pope live in the woods?
    Yep, by the % increase over the original length.
  20. "bad vacuum advance diaphram."
    Correct.
    The vac advance diaphragm had a pinhole, fuel laden fumes would travel into the un-vented distributor cap, points would arc, small explosion took place which blew the cap off the distributor body . . . but not too far.
    New vac adv unit, bending the clips for a little stronger hold and drilling a small hole in the dist cap to vent it cured the problem.
    "synchronous motors? doesn't that have to do with the frequency times the number of poles minus one or something? just guessing, it's been a long time."
    Pretty darned close, I'll give it to you.
    Not many have ever answered this somewhat obscure question.
    One of those fallback deals in contests like this one.
    60 hz three phase system - 120 is the phase angle:
    60 x 120 divided by the number of poles.
    IE: 60 hz system with a two pole machine = 3600 rpm.
    Same system with a ten pole machine - 720 rpm.
    Both machines, although running at different physical RPM are running at the same electrical speed therefore can be operated in parallel.
    Bulk power electricity is weird stuff....
  21. squirrel
    Oh, I was thinking single phase :)
  22. SinisterCustom
    SinisterCustom
    The steering isn't that slow on the manual aluminum MoPar boxes.....I used one in my Charger to get rid of the PS. Most A-bodies used it....not just '70.
  23. blown49
    blown49
    Cause it had a Mallory 4 lobe Rev-Pole dizzy with only 1 set of points in it?
  24. Smokin Joe
    Smokin Joe
    Duh, first stop the car so the parts aren't moving.:p
    OK, Easy one:
    My daddy's name is Henry. I'm 7 inches and I've got 2 nuts and go in and out, in and out...
  25. GTS225
    GTS225
    Hmmmmm......I'll try.
    How many frost plugs are in the left side of a Mopar slant six block?
    (Clue....you should ask a question before answering.)
    Roger
  26. Yeah what side?
  27. squirrel
    iron or aluminum block?
  28. slacker91
    slacker91
    from Emmaus, PA
  29. Crusty Nut
    Crusty Nut
    So, you played with Fiddys box and fell in love. Right on for you.:rolleyes: Where is the plowboy, sounds like **** time.:eek:
  30. hilbillyjim1948
    hilbillyjim1948
    from australia
    which of the big 3 produced the fastest inline hemi over the 1/4 in a production car?
