Continental 6 cyl bearings.
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Jun 15, 2010.
  1. metalshapes
    metalshapes
    A friend of mine has a '29 Chevy with a '33 Continental 6 cyl in it.
    I'd like to help him find a company that can supply him with bearings for it.
    Does anybody have any tips of where to start searching?
    Thanks.
  2. gimpyshotrods
    gimpyshotrods
    These lingered on in propane powered forklifts for quite some time, some as late as the the 70's.
    I put a head gasket on a 1971 Baker (was part of Otis elevator) forklift a few years ago, with a Continental in it. I think Clark used them too.
    Might check with your local forklift shop, preferably the one that has been in business since the dawn of time, if you have one.
    Continentals, at least the 4-cylinder ones, were used in mobile welders, as late as 1990. There may be some sixes in there too.
    If you can get me the model number on the engine, I can look out here too.
  3. junkjunky
    junkjunky
    some of the m***ey-harris tractors had continental engines.you might try a tractor supply.
  4. caddydave
    caddydave
    You might try Jerry Biro in Ohio. 740-745-1475. He sells Hercules and Continental industrial engine parts.
    Good luck, Dave
  5. Make sure you get the right model # there are many variations of the Continental 6 over the years, even if they look the same on the outside.
  6. metalshapes
    metalshapes
    I didnt know these were the same as the forklift engines.
    Could it be a Chevy engine with nickname?
  7. gimpyshotrods
    gimpyshotrods
    Sadly, no. That would solve a lot of problems, though.
  8. metalshapes
    metalshapes
    Thanks for the Info, guys.
    I'll ask him exactly what engine he has.
  9. Might also try Egge Machine....http://www.egge.com/
    They generally have a lot of stuff that isn't catalogued or on the website.
    As others have said, the various Continentals were used for years, so it shouldn't be too rough to find parts.
  10. JohnEvans
    JohnEvans
    from Phoenix AZ
    Let's see a picture of the engine. If OHV not likely to be a Continental.Chevy had some strange model names back then.
  11. LowKat
    LowKat
    The 1958 Pettibone at my work has a Continental.
  12. fordcragar
    fordcragar
    from Yakima WA.
    I have a 68 Towmotor forklift with a Continental flathead 6 in it.
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    40s and up small Contintals are all very simular to the last of them 70s somewhere. But the earlier ones are a lot different internally not much if anything will interchange. Worked at a place years ago that was a Continental dist.
    edit
    Did a little Googleing and found 32 Chevys used " confederate" as a model name/series. Wonder if this might be where the "Continental" idea came from. Anyway bottom line a few good pictures would sure help.
  14. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I would try a Caterpillar dealer. When I had a Towmotor (Cat) it had a Conti 4 banger in it.
  15. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Also, could a machine shop make something more normal fit? Like a Chevy bearing?
  16. Mr48chev
  17. 29nash
    29nash
    from colorado
  18. JohnEvans
    JohnEvans
    from Phoenix AZ
    Well 29nash good try but all those engines listed are 40s up stuff. Earlier ones are a lot different. But with out a pic or 3 we are just ******* in the wind.
  19. metalshapes
    metalshapes
    Yeah, I Emailed my buddy and told him we need engine numbers & pics.
    I'll ask more questions when I have those.
    Thanks for all the help, guys.
  20. AllSteel36
    AllSteel36
    Man I hope this is photochopped!
    (PS my old Clark (circa 40's) lift has a Continental too.
  21. Try mandmsurplus.com
  22. Saxman
    Saxman
    Did the early Continentals use insert bearings or were they babbit pounders?
