Contraption
Discussion in 'The Hokey Ass Message Board' started by ArtGeco, Mar 14, 2012.
  1. ArtGeco
    ArtGeco
    from Miami
    I just torched the bottoms off the valves.
    Pried the valves open and used a cut off
    wheel and chopped the top of the valves
    off. Then hammered the guide with the
    remainder of the valve in and they just fall
    into the block.
  2. ArtGeco
    ArtGeco
    from Miami
    Finally, all tore down...
  3. ArtGeco
    ArtGeco
    from Miami
    Hey Nads, what's shaking Man.
    It's my first flathead, and yes it's
    been tough so far and expect it
    won't get any easier but right now,
    I'd take on another one.
    You oughta' try and make it down for
    a beer and BBQ sometime. I think you're
    only 45 minutes away, right?
  4. ct1932ford
    ct1932ford
    Whats wrong with the ***le:rolleyes: Here is a car from the late 50's in Stamford CT. Where do you think his driveshaft is?:cool:
  5. 1964countrysedan
    1964countrysedan
    from Texas
    Thanks for taking the time to post this build. I am digging it!
  6. Nads
    Nads
    from Hypocrisy
    4 hours, I need to go down there soon.
  7. Von Rigg Fink
    Von Rigg Fink
    from Garage
    wild man, i can dig it
  8. ArtGeco
    ArtGeco
    from Miami
    So, Change of Plans. I was cruising Craigslist when I see my Pal Yaril (TylerDurben)
    had a motor and trans for sale. A deal was made, he said his goodbyes and he saved
    me a lot of time, and probably money too. It's a 50 ford flathead, runs sitting on the
    pallete, best of all, Overdrive trans, woohoo!
  9. Dog_Patch
    Dog_Patch
    Oh man that was a good score there! Now you can drive to Billet Proof this year!
  10. ArtGeco
    ArtGeco
    from Miami
  11. Don't take it apart unless you absolutely have to. There are a lot of good running flatheads (and other motors as well) that have cracks that have healed themselves. Once you disturb the relationships they are junk.
  12. looking good bro.........
  13. Liam-B
    Liam-B
    from Melbourne
    Good score on the flat head motor, much easier than fixing up your previous one!
  14. ArtGeco
    ArtGeco
    from Miami
    Been working on the wishbones.
    A lot of heat, cutting, measuring, fabricating
    and time working while sitting on the floor.
    but the results were worth while...
    Decided I wanted a day standing up, sipping on beer at the work bench.
    Cleaning and rebuilding the steering box it is.
    Cleaned all the junk off the outside.
    Forgot after pics but everything cleaned up fine.
    After it was all back together.
  15. Beau
    Beau
    What. The. F@ck.
  16. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    will a motor fit in it? once the motor and yourself are in will it drag its *** like a constipated dog?
  17. kirby1374
    kirby1374
    I don't think he has the springs in it yet....
  18. Beau
    Beau
    I suppose. If the springs raise it about 7-8" the suspension will work.
    The carb is still going to be in the gas tank though.
    I like the idea. I'm not sure if he is teasing us or actually thinks that will work.
    I'm still new to this myself. But my hours upon hours of researching and reading opinions and facts made me think long and hard about every little detail for my suspension and drivetrain. Maybe I'm missing something here.
  19. Blue One
    Blue One
    from Alberta
    Worthwhile ?? Sorry but I think you are delusional. I agree with the previous poster, maybe the springs arent in it and it will sit better with them :confused:
    I liked the ****ogy earlier, once you and the engine are in it it might look like a constipated dog dragging it's ***, or a dog with worms dragging it's *** to relieve the itch :D
    As it sits in this picture it just look rediculous.
  20. VoodooTwin
    VoodooTwin
    from Noo Yawk
    She's sitting a bit low, but I really like the direction. It's looking bad ***.
  21. HOTRODPRIMER
    HOTRODPRIMER
    I'm sorry but this build is going in the wrong direction. :confused: HRP
  22. R Pope
    R Pope
    A cabover Model A???
  23. millersgarage
    millersgarage
    not my car, not my ideas, but I'd like to see that body moved back over the rear axle.
    and maybe some added to the wheelbase.
  24. VonKool13
    VonKool13
    His car, his time, his money. Keep it up, its gonna be a cool little modified.
    Sent from my DROID device using the TJJ mobile app
  25. Blue One
    Blue One
    from Alberta
    Not likely :rolleyes: , more like a Rat Rod modified :D
  26. fordman1
    fordman1
    maybe a little benefit of the doubt since it is still in mock up mode? I like the collection of parts and ingenuity to use cast off parts!
  27. Blue One
    Blue One
    from Alberta
    I think he's too embar***ed to come back :)
  28. thewishartkid
    thewishartkid
    I'm not sure what your trying to build, But i have my doubts.
  29. cfnutcase
    cfnutcase
    from Branson mo
    I have seen some cool **** that people have pulled out of their ***es so I will just wait....some of the stuff I have done has looked really bad but ended up OK....I will not judge till the end. Jim
  30. I liked what he started. Not sure where it's headed. I'll hold my tounge till then...........................................
