Convert 64-73 Ford 4-speed to top shift?
Discussion in 'The Hokey Ass Message Board' started by harrisoncarroll, Jan 21, 2012.
  1. harrisoncarroll
    harrisoncarroll
    from Ohio
    Good afternoon,
    I am interested in converting a 64-73 Ford Toploader 4-speed transmission to shift on the top. I know this can be done with a Jeep T-176 shifter ***embly (if you notch the case and remove the internal shift forks).
    My question is can it be done with a Ford T170TS shifter ***emble (all aluminum Tremec 4-speed with 4th being overdrive used in 1984-85 Ford trucks)? The reason I am asking is because I already own a T170TS transmission and used T-176 shifter ***emblies are getting harder and harder to find and more and more expensive.
    Any help would be greatly appreciated.
    Thanks,
    Josh
  2. R Pope
    R Pope
    I see no reason why it will not work, the gears are basically the same. The main problem with those aluminum ******s was the ****py shift mechanism was always wearing out, removing it should make a better setup.
  3. 56don
    56don
    Is this the one you are talking about?
  4. harrisoncarroll
    harrisoncarroll
    from Ohio
    Yes, the picture you posted is the ******.
    Thanks,
    Josh
  5. falconsprint63
    falconsprint63
    from Mayberry
