Technical Convert disc to drum
Discussion in 'Traditional Hot Rods' started by Domesticsonly, Dec 11, 2018.
  1. Domesticsonly
    Domesticsonly
    Working on my 29 Es*** coupe and the previous owner added a drop tube axle with what I believe are Chevy spindles that have been modified for Mustang IMG_20181211_165334.jpg IMG_20181211_165326.jpg discs. I'd like to ditch the discs and go back to drum. I would like to keep a 5x4 1/5 bolt pattern. I could probably just run original Chevy spindles and brakes but I'd have to redrill the bolt pattern (if that is doable). Is there an easier/better solution keeping the spindles I have?
  2. paul55
    paul55
    from michigan
    Those are 49-54 Chevy p***. car. You just need some backing plates/drums from someone doing a disc conversion.
  3. 34Phil
    34Phil
    And spindles. Speedway machines them for the MII discs.
  4. Domesticsonly
    Domesticsonly
    Cool. Thanks...to keep the 5 x 4 1/2 bolt pattern is it feasible (safe) to redrill the original Chevy hubs and drums?
  5. tub1
    tub1
    from tasmania
    id be looking for some steering arms of the chevy as well
    F&J likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    I used a similar steering arm on a 37 for many many miles no issues . If you do decide to keep the steering arm safety washers MUST be installed on all HEIM joints attached to steering linkages . There are specific size spacers between spindle and backing plates also . You may have a bearing adapter for the disc brakes that will need to be removed to allow you to reinstall the hub on drum brakes . I think 64 Hubs will give you roller bearings also vs. ball bearings on the earlier hubs .
  7. Mr48chev
    First step is to pop the hub and rotor off and see how they put that hub on the Chevy spindle. As the guys said there are a couple of ways to do it. Machine the spindle for the MII bearing or slip on and adapter/spacer that lets you use the MII spindle and bearing on the stock Chevy spindle.
    squirrel likes this.
  8. squirrel
    that trick only works on the 55 and later spindles
