Convertible rear window: help wanted
Discussion in 'The Hokey Ass Message Board' started by 50Fraud, Nov 3, 2012.
  1. 50Fraud
    50Fraud
    I'm looking ahead to the rear window for my phantom '40 Ford convertible.
    The stock Ford rear window, as I recall, was basically a gl***ed-in mail slot:
    ...but I'd like to see more to the rear. Some guys put in an all-plastic rear flap; I don't want to do that:
    Here's a chopped convert with a window that appears to be stock height, but a little wider:
    That's a step in the right direction, but I'd like a little more height too. Anybody have any advice regarding this type of window, like where to find them, larger-than-40 sizes, if any were used; any other intelligence would help??
  2. ol fueler
    ol fueler
    I see no reason that a top shop ,( Do they even have such things any more?)could not make a rear plastic window that is whatever size you want and insert it in the top material by sewing it into the zippered flap.
  3. 50Fraud
    50Fraud
    I'm sure you're right, but a plastic window is what I DON'T want. To look at least fairly correct, I intend to use a gl*** window in a chrome frame similar to the stock window. The issue is that the stock window is very small, and offers very little rear vision via the mirror or looking over your shoulder.
    I'd like to use a larger window than stock, but I'm not much interested in fabricating the frame from scratch. The purpose of this post (guess I could have stated this more clearly) is to get suggestions about the availability of a chrome framed window, or an empty frame, in sizes larger than the stock '40 window.
  4. manyolcars
    manyolcars
    I dont blame you for not wanting to build from scratch, so take a piece of stainless, cut it to any size you want and get a gl*** to fit
  5. rustythumb
    rustythumb
    how about a model a sport coupe back window?
  6. rw4951
    rw4951
    Check with LaBaron Bonney. I believe they have several different size "mail slot" frames with gl***.
  7. OLDSMAN
    OLDSMAN
    I used a back window from Lebaron Bonney in my 48 Olds 98. They have various sizes to choose from. TGhey market a very high quality product
  8. 39 Buicks were about 28 inches wide.
    s
  9. 50Fraud
    50Fraud
    LeBaron Bonney it is! Thanks!
  10. 36cab
    36cab
    Here is the link to LeBaron Bonney's on line catalog. The Ford rear window frames are on page 78. It looks like a 40 Ford ha s 6" x 20-15/16" frame, The 49-50 Ford looks to be the biggest frame at 9" x 26".
    http://www.lebaronbonney.com/catalogforweb.pdf
