1952-59 Ford Convertible top relay
Discussion in 'Off Topic Hot Rods & Customs' started by okiedokie, Feb 21, 2017.
  1. okiedokie
    okiedokie
    from Ok
    I am stumped as to the relay that controls the top. I have switched to 12 volts so I ***umed that I would need one from a 56. However, I can find no supplier that shows one, 6 or 12V. I wonder if it really makes a difference as to 6 or 12V. Wonder if I can use the original. Anyone have any info regarding this?
  2. 54vicky
    54vicky
    if it is similar to power window relay it will be a constant use relay.mine is 6 volt so no help with part #.if you search cole hersee catalog I am pretty sure they list one.that is if by relay you mean the solenoid type relay
  3. okiedokie
    okiedokie
    from Ok
    It is not the same relay as a power window. I have searched all the catalogs with no luck.
  4. 52ragtop
    52ragtop
    from Nebraska
    A 6V relay will hold the 12V all day long, but I hope you have a 12V motor. or motors depending
  5. 54sunliner
    54sunliner
    Can you use a voltage reducer before the relay is powered?
  6. okiedokie
    okiedokie
    from Ok
    I wonder if the 6 volt switch would also work with 12 volts to it? I do have a 12 volt pump.
  7. Slicks
    Slicks
    from denison tx
    Yes it will it will work fine
  8. okiedokie
    okiedokie
    from Ok
    Ok, thanks to you guys I will use original switch and relay with the new 12v pump.
  9. okiedokie
    okiedokie
    from Ok
    Thanks to Rich [Texas57] posting this over on the 57fordsforever forum showing that 57's used no relays I can see that I can use the universal 12V top switch that I purchased to operate the pump motor. I wondered why those switches all the top guys sell were 50 amp.
