Converting 6 volt to 12 volt
Discussion in 'The Hokey Ass Message Board' started by sp1ke, Nov 16, 2011.
  1. sp1ke
    sp1ke
    HELP,
    When converting 6 to 12 volt on a 50 ford the starter ****on is grounded to the dash. How do you stop this? I do not want to put an after market ****on on as it will reflect on the dash. I would like it to look stock inside the car.
    thanks
    sp1ke
  2. tb33anda3rd
    tb33anda3rd
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    You need a insulated base 12V solinoid . Cole hersey makes them. I don't have a electrical auto parts buyers guide or I probably could give you a number that would work at the FLAP store. Or use a relay.
  4. Mike51Merc
    Mike51Merc
    As noted above, you need a 12 volt neg ground solenoid, which are very common and just about any post-1956 Ford solenoid will do. The old solenoid was triggered from ground (hence the one wire), the new one will be triggered by positive voltage, meaning it needs to be fed by a positive source coming from the starter ****on.
    You'll also have to replace the starter ****on with a pole switch and run power to it, with the other leg running to the solenoid.
  5. sp1ke
    sp1ke
    Thanks to all for your help. Very much so--sp1ke
  6. davo461
    davo461
    Can you run the two-wire solenoid "hot" and use the original starter ****on to complete the circuit to earth?
  7. tedster
    tedster
    Ron Francis sells a two wire starter ****on that looks real close to original. You will have to enlarge hole in dash just a little for it to fit.
  8. themoose
    themoose
    This should work
  9. daliant
    daliant
    Use a solenoid for a Western Ultra or Uni-mount snow plow, it uses ground to trigger it like the original.
  10. 49 Custom
    49 Custom
    I second this suggestion. Is is exactly what I used; it's simpler and very similar to the original.
  11. d2_willys
    d2_willys
    from Kansas
    Which solenoid are you using in your diagram? Might help to know these things.
  12. themoose
    themoose
  13. Flat Ernie
    Flat Ernie
    Tech Editor
    The other thing you can do is simply leave the 6V starter relay installed. It will work just fine on 12V as it's momentary duty and not a continuous duty item. No changes required.
    Or, you can do as above and find the tractor starter relay that can be back-ordered, or wire in a relay, or replace the starter ****on with a two-wire ****on.
    Of the four options, I prefer simply using the original 6V starter relay - many of them have a manual ****on on the bottom so you can bump the engine over from under the hood...
