Converting an old Hilborn to electronic and to use a Vertex.
Discussion in 'Off Topic Hot Rods & Customs' started by Watson & Weldon, Nov 13, 2024.
  1. Watson & Weldon
    Watson & Weldon
    Most of my friends say you cannot do that. I feel somewhat confident adapting the FI; however, am concerned about the mag interfering with the computer for the FI. The mag did not cause any issues with the instruments in the race car; but, there was not a computer involved. I recall back in the sixties that some guys wrapped a thin gauge copper wire around the plug wires and grounded it; but. there were no computers then. Is the electrical interference from the magneto body or plug wires or both? Is there a means to contain that interference?
  2. gimpyshotrods
    gimpyshotrods
    The EFI is not going to be popular here.
    The answer is yes, both.
    The plug wires and the magneto will both produce EMI.
    It is hard to say exactly what effect that will have on electronic components, though.
    Most modern stuff rejects interface fairly well, but the same cannot necessarily be said for home-brew stuff.
    Johnny Gee likes this.
  3. Harv
    Harv
    from Sydney
    If it is a Vertex magneto, then there are solutions to control radio frequency (RF) interference. They work by making a Faraday cage around the parts that can emit RF.
    There is a factory aluminum hood, as per the images below:
    The hood prevents RF interference from the cap area. The hood "outlets" let the plug wires exit. The plug wires are covered in stainless braid, connected to the hood and earthed to the block. This prevents RF interference from the leads.
    Cheers,
    Harv
    tractorguy, Deuces and 19Eddy30 like this.
  4. PotvinV8
    PotvinV8
  5. 19Eddy30
    19Eddy30
    from VA
    I have not seen one of those,
    About what year introduced & is it a Vertex?
    The Efi will need a Rpm signal, I think you could fake it , a crank trigger wheel or take a add 4 magnets 90 deg from each other to balancer , flex plate Ext with pick up to
    Reference rpms to ecu to operate injectors, Im sure other ways ,
    & Mag just send spark to plugs ,
    I am just sharing a thought .
  6. Harv
    Harv
    from Sydney
    Not sure what year they were introduced, but definitely Vertex factory gear. The picture below is an excerpt from the Vertex instruction manual.
    Cheers,
    Harv
    tractorguy likes this.
  7. RodStRace
    RodStRace
    I don't know if this is a home brew or aftermarket. If home brew, lurk on the FI conversion companies for as much info as possible. If bought, ask them.
    For shielding, First look at stuff like BB corvettes.
    The immediate question is - was the whole point of running old ignition with new fuel for the looks, because this isn't going to make you happy. It also begs why you want to go modern and old school when they aren't really compatible.
    If you gotta have it, try to keep the computer stuff away from the mag, and no long parallel runs.
    You can also get shielded wires for the EFI and then also run them inside a shield.
    You might talk to local HAM or other radio hobbyists near you about EMF.
    G-son likes this.
