Converting early ford gauges for 12V
Discussion in 'The Hokey Ass Message Board' started by Koz, May 25, 2009.
  1. Koz
    Koz
    I'm working on using '40 Merc gauges in my A with the 283 Chev engine. I know the speedo is a bolt on to my '40 Ford rear and I have the correct drive gears for the same.
    Anybody know-
    Can I just use the early Ford sender and a voltage drop, (Runtz), on the Fuel gauge? Can I use an early Ford Oil pressure sender and a voltage drop on the Oil gauge? Can I do the same on the Temp? How do I wire up the Ammeter, and will it work on 12V?
    I only want them to work untill the fall when I will send them out to be rebuilt/refinished and recalibrated. I just want them to work for now so as to get some miles on the car while it's warm.
  2. i have used several `40 ford gauge clusters with sbc's and i used the stock fuel, oil and temp gauges with runtz on the power to the gauges. use stock `40 ford senders and all worked fine.
    double check to see if the `40 mercury actually has a amp gauge or is it really a volt gauge. if it is an amp gauge you should have no problem using as is , amp gauges do not care about volts. but if it is a volt gauge like a `40 ford.... do not use a runtz on it. a runtz regulates the voltage to a constant 6 volts , so you would not see any difference on the gauge between charge and not charging. i use a 60 ohms resister in the power for the volt gauge and then it works properly. when you turn the ignition on without the motor running the gauge goes to about 1/2 scale. after you start the motor and the alternator starts charging it moves up a bit more. this resister was told to me another here on the Hamb , maybe he will see this and jump in
  3. Ford actually used 6 volt gauges well into the 60's with a voltage reducer in the gauge feed circuit.
  4. Koz
    Koz
    I think I've got all the info to use these gauges from this thread and the tech archives. The worst I do is have to have one rebuilt which I'm going to do anyway. Decided on the Ron Francis solid state voltage source and origional senders. I'm going to see if I can get my SW fuel sender to work,( need to check Ohms), if not Macs has the right one.
    Thanks guys.
