Technical Converting to 12 volt
Discussion in 'Traditional Customs' started by Chris C Kennedy, Mar 13, 2022.
  1. Chris C Kennedy
    Chris C Kennedy
    1931 ford hot rod W/ 239 flathead changing to 12 volt. What is the best group number battery that will give me the best fit.
    Thank you
    Chris
  2. BJR
    BJR
    Get a tape measure and go to an auto parts store that has a battery display, or look on the internet for a battery size chart. The info is out there.
    mitch 36 likes this.
  3. pprather
    pprather
    The best size is the one that fits in your battery tray/box.
    Bob Lowry and Bandit Billy like this.
  4. If your A uses the group 1 6 volt battery, the group 59 battery fits very well. That is the battery I use when convert old Farmall tractors with completely enclosed battery boxes
    Bob Lowry and loudbang like this.
  5. dan c
    dan c
    i just take my battery box to autozone (believe it or not) and they always find something that works!
    Bob Lowry likes this.
  6. Bandit Billy
    Bandit Billy
    And has the terminals in the right place.
    loudbang, Bob Lowry and pprather like this.
  7. I personally like (some people don't) side terminal batteries because of better resistance to terminal corrosion. I went to side terminal on my truck and my '55 Ford. As others have said, measure your battery tray. Not hard to find a battery that will fit a tray that was designed to fit the common Ford size 6 volt, use a universal replacement hold-down from the parts store.
  8. MeanGene427
    MeanGene427
    from Napa
    I have converted two old Ford tractors, an 8N and an 850, and a Group 35 12V fits the original battery box very well
