1952-59 Ford Converting your Y-Block to alternator?
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Jan 12, 2011.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. dragonknucks
    dragonknucks
    Jeff, I think you sent me this link a while back. This is what I'm going to use for my new shiny alternator. I'll be posting pics as soon as possible.
  3. Retro Jim
    Retro Jim
    I have seen a different set up that use to sell on Ebay .
    They look easy enough to make up yourself but sometimes I get too lazy and would rather just pay someone else to do it for me . :eek:
    I am not sure if it's lazy or the years catching up to me real fast . :(
    I am hoping I am just getting to damn lazy to make some things like I use to ! :cool:
  4. Joe-Racer
    Joe-Racer
    Hey Jeff, I found this post on a search. The link that you have posted is dead, or goes to some generic page. Do you know of other sites with good info?
    Thanks
  5. streetdreams
    streetdreams
    Even if you're going to buy a bracket set up, you need to make sure it's designed correctly for it to work properly and have some durability. I've replaced a couple
    of " store bought " set ups on FE engines with alternator updates because the brackets wouldn't keep the belt tensioned. They bent and flexed.
    You need three points of mounting if you're using a Ford or GM style alternator with the pivot bolt throught he housing.
    1) you need a solid point for the pivot bolt to attach to, like a threaded hole in the block, cylinder head or a steel plate mounted to the engine.
    2) you need a bracket running from the front of the alternator at the pivot bolt head that attaches to another solid point.
    3) A third bracket is needed from the adjusting bolt on the alternator to a solid point to allow belt adjustment.
    Otherwise, the mounting bracket will flex, allowing belt tension to decrease.
  6. Joe-Racer
    Joe-Racer
    Yeah streetdreams, I understand that. I'm running the stock Y-Block, changing over to 12v. There is a setup on eBay for $120. plus shipping. I'm just too stinkin' tight to spend the cash on it. Looking for a safe, effective poor-man setup.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    A couple of months ago someone hacked the ranchwagon site with a virus and it has been shut down.
  8. dragonknucks
    dragonknucks
    Joe-Racer I also converted my y-block to an alternator. At first I just used some threaded rod and spacers to make a bracket, it was horrible. So I finally decided to spend some money and have a nice, reliable part. This is what I ended up with and couldnt be happier. http://ford-y-block.com/alternatorbrkt.htm
    Hope this helps some. - Rocky
  9. Joe-Racer
    Joe-Racer
    Hey Dragonknucks, that setup looks great! I like it much more than the kit I looked at on eBay. I hate to come across as a cheapskate but it seems to be such a simple setup it hard to justify $120. plus shipping. The cast aluminum looks better and cost less too!
    Thanks again Dragonknucks!
  10. 1 Ford fan
    1 Ford fan
    I bought a set up for GM alt. and AC compressor. I actually bought 2 and have them in two cars. Work great a Texas suplier. Can't remember his name "Hide"? if you are interested I'll look uo an invoice. Gerry
  11. 1 Ford fan
    1 Ford fan
    found it. hate being over 50...
    Fordcraft
    124 Ridgeview Drive
    Murphy, TX 75094-3218 map
    Phone:
    (972) 423-4636
  12. 1 Ford fan
    1 Ford fan
  13. losthutch
    losthutch
    from wisconsin
    Ok probably a serious question,by what's the point of converting from the generator to the alternators?
  14. streetdreams
    streetdreams
    Alternators put out more charging amps than most generators. Alternators also charge more at lower rpms, but that's not always the case with some older Ford and GM alternators. Overall, they charge at a higher rate over a larger operating range than a geneator.
    If you're adding more electrical load to your car, especially in the sound department, you need to upgrade.
  15. losthutch
    losthutch
    from wisconsin
    Oh,well that I don't have to worry about right now.
  16. danman55
    danman55
    If anyone chooses to go the LD Becker route out in Ohio, I can vouch for their quality and customer service. Their alternators are warrantied for LIFE! I did have to use it once as I had one setup on an engine run stand that burnt out on me. They replaced it with new one, no questions asked.
  17. Vintage Air has an alternator mounting system for Y Blocks.
    TC
