Cool non-hemispherical Mopar motorvation
Discussion in 'The Hokey Ass Message Board' started by True, Jan 22, 2006.
  1. 57JoeFoMoPar
    57JoeFoMoPar
    Hard to beat big block MoPar power. Wedge heads are good for making decent power too, especially those 440s. Better yet, stroke it to a 500 and raise hell like no other.
    They look and sound good too. here's my 383
  2. blue57ford
    blue57ford
    I used to own a 65 plymouth belvedere two door hard top with the original poly 318. That was one of the best running motors I have ever driven. I miss that car alot and kick my self in the *** for selling it. Wish to hell I could have another one.
  3. Yo Baby
    Yo Baby
    So what's up with the Algons if the SBC is out?
  4. scope out the 383 golden lion engine, perfectly good 50's mill (cool valve cover logo to boot.)
  5. SimonSez
    SimonSez
  6. Jonnyhotrod
    Jonnyhotrod
    Here's my coupe which is scheduled for the road in the Spring. Channeled 6 inches, unchopped. I'm running a 413, Push-****on TorqueFlite, torque-tube headers, and eventually the long-ram intakes (after working the bugs out w/ 1 AFB). I don't care to 'dazzle anyone blind', as this is meant to be a simple clean street car. The RB motor with anything feeding it is nice factory HP and enough low-end torque to rip your face off. This was taken about this time last year.
    Jonny
  7. SanDiegoJoe
    SanDiegoJoe
    I would go for a Slant 6... My car came with a 170 and has a 225 now... great little engine. Plus it looks pretty damn cool, especially if you can score a hyperpack intake.
    Joe
  8. BigBlockMopar
    BigBlockMopar
    Here's another vote for the B/RB-engines... :D
    JonnyHotRod, cool 'rod you're making there. Wouldn't mind seeing some (project) pics of it.
    LongRams rule... :D
  9. 57JoeFoMoPar
    57JoeFoMoPar
    WOW!!! I think I need some alone time with this pic!
    How are cold starts with the long rams. Must be hell to get started, but once started must raise Hell!!!
  10. BigBlockMopar
    BigBlockMopar
    Well to be honest, I've never driven a car with a setup like this before, so I have no experience in that field yet.
    I do know that every engine will start as long as you put enough fuel in it... :D
    I bought this setup some years ago on a swapmeet in Phoenix, Az when I was there on vacation. Haven't had the opportunity to do something with it. The longrams on the engine shown are just a mockup. I've plans to put these longlegged ladies in my '62 Chrysler wagon pretty soon, but I need to alter the entire braking-system on the firewall and under the dash. So it will be quite a project I'm afraid.
    Here's another pic of the tubes...
  11. Has anyone ever fabricated a long runner cross-ram out of tube steel? Is there any reason to believe that it wouldn't work?
    The original cast units,though things of fiercesome beauty, are iron right? If not tube what about cast aluminum repros of the iron ones?
    Oops! Hijacking in progress! Sorry!
  12. BigBlockMopar
    BigBlockMopar
    These longrams are made of cast aluminum.
  13. you beat me to it...
    Is there some type of support to prevent vibration (along with the weight of the carbs) from breaking the manifolds?
    Did the long-ram intake manifolds mount to special exhaust manifolds for support and heat?
    I have never seen a set on an original installation...
  14. BigBlockMopar
    BigBlockMopar
    Yes, the original exhaust-manifolds had 2 small heatriser-tubes per side running up to the carb-wells for support and to heat up that area.
    I haven't got good pics of the complete setup at the moment.
  15. zimm
    zimm
    from iowa
    hmm not much of a mopar guy but want to learn... what dose the term (poly) refer to? please explaine
  16. plym_46
    plym_46
    from central NY
    referred to Polyspheric heads, AKA semi hemi. Basically a hemi block with redesigned (read less expensive) single rocker heads. They retained some of the breathing atributes of the hemi but were lighter and less compliated than the dual rockershaft HEMI. Check the engine history section of
    http://www.allpar.com
    for more info.
    Also
    http://www.geocities.com/motorcity/track/4164/
