History Cool old round track beater. 34 Chevy. GMC powered?
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jan 20, 2023.
  1. Pooped up on FB.
    Cool coupe
    CEA16836-8488-4E10-9FE3-92FB30E6C10D.jpeg FD0E1D91-75AD-4AC8-9D3F-3AA367B2E5F9.jpeg D74B84E9-6CF5-40AB-9075-E19EBCB0853D.jpeg
    Cosmo49, Tim, Nailhead A-V8 and 20 others like this.
  2. Has some gmc speed parts according to the post
    7FA2AF63-3CB3-4A23-A399-D3F2E71D6CCC.jpeg 0FAC4A0E-F7FE-4F00-AE24-A319F101D2F8.jpeg 683BFEAA-4A4E-445E-B1A1-D6276524BB72.jpeg 63B02F12-D30B-4C76-AE50-4702F2F273FD.jpeg 6E8272D8-4345-4B76-9C0F-21E12C4443BA.jpeg
    Cosmo49, Kreepea_1, Tim and 22 others like this.
  3. Would somebody, I say would somebody please rescue that vehicle and put it back on the track. Please.
  4. guthriesmith
    guthriesmith
    That is pretty cool! :cool:
    210superair and anthony myrick like this.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Definitely a GMC engine with high compression pistons for use with a 302 head, but both intake manifolds are Chevy. Interesting.
    D-Russ, Offset, Torkwrench and 3 others like this.
  6. I was confused with the intakes.
    I was also under the impression those parts wouldn’t be on a round track ride.
    But I’m no expert on rules of the time
    looks like a magneto.
    Would that had been allowed as well?
    Offset and chryslerfan55 like this.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    In the higher cl***es, yes.
    anthony myrick likes this.
  8. That’s cool.
    Didn’t know that
  9. Marty Strode
    Marty Strode
    Those early Chevy coupes made good Hardtop racers, with 4 springs, they were stable in the turns. Shot from our local Fairground track, (5/8 mile dirt) around 1958. Hillsboro Fairgrounds.jpg
  10. WB69
    WB69
    from Kansas
    Where's it located?
  11. Marty Strode
    Marty Strode
    texasred and anthony myrick like this.
  12. Here is the add
    catdad49, Offset and Okie Pete like this.
  13. Just noticed the Ford front axle set up.
    Cool
    Aluminum drums?
  14. Almostdone
    Almostdone
    What’s the doohickey that looks like a turbocharger?
    John
  15. Don’t know.
    Looks like this cars owner bought an old car with a bunch of random parts.
    VANDENPLAS likes this.
  16. Centered steering/offset modification?
    Interesting
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I was trying to figure that one out myself.
    VANDENPLAS and anthony myrick like this.
  18. sololobo
    sololobo
    OMG, that is awesome! Looks like my fab work inside!
  19. Max Gearhead
    Max Gearhead
    from Wisconsin
  20. tubman
    tubman
    That's a magneto on the engine. From my experience, that makes this a high end car. I would bet that enough research would bring up some interesting history.
    And yes, those are Buick aluminum drums. I notice that there is what looks to be a 3/4 ton full-floating Ford truck drum on the right front (there is a car setup on the left front). That's also serious stuff. I have the same thing on my dirt modified which was Minnesota State Stock Car Champion in 1966 (with a magneto). As said above : "Someone buy this car!". Racecar 002.jpg
  21. The add had this right up
    2Blue2, catdad49, Offset and 4 others like this.
  22. 1952henry
    1952henry
    Gotta.ask, would.you drive it, Anthony?
  23. Yep.
    Make it go and stop.
    Find some numbers and tag it.
    I’d drive it to work
    Then to the track for some hot laps
    rusty valley, Offset and WC145 like this.
  24. stanlow69
    stanlow69
    It`s a shame the stuff has been sitting so long. But at least it`s all together. Should all stay together too. But someone will split it all up to get the most return for his buck.
  25. gene-koning
    gene-koning
    The thing on the firewall is to offset the steering. The original steering shaft is on the left side of the attachment and the end is supported by a bearing. It probably has a roller chain connecting the original shaft to the relocated shaft attached to the steering wheel.
    I wonder if the thing that looks like a turbocharger might be an oil pump, or a water pump. It has a belt pulley on one end, and the motor has two lines plumbed into the engine block.
    From the pictures, the front of the car looks pretty short to have an inline 6 unless the motor is set back pretty far, or the front axle has moved forward enough to make the front look short. Had to have the Ford front axle setup, there isn't enough room in front of the axle for the GM leaf springs.
    That body is pretty straight, makes a guy wonder how much real track time its seen. Maybe they couldn't get everything to work well enough to be compe***ive, or maybe it got caught between the rule changes changes, or maybe it didn't get done (or redone) and never saw track time.
  26. alanp561
    alanp561
    I ran a very similar setup on my Fords but the sprocket on the steering wheel side was larger than the one on the steering shaft. I can't remember the number of teeth on each sprocket but it quickened the steering to the point that I barely moved my hands going through the turns.
  27. Go right ahead. Permission granted.
    Ben
