Cool Small Block Ford Valve Covers
Discussion in 'The Hokey Ass Message Board' started by TexasHardcore, Mar 3, 2005.
  1. woodywagon1965r
    woodywagon1965r
    the link i found on tall valve covers was off the second page of this link by tedley saying check out these bad boys from cobra valley just click on the line there will send ya there tried to email them off that but my comp wont let me
  2. Algon
    Algon
    Boss 302 made to look like a Nailhead? I'll you give a real iconic Nailhead for any lowly Boss motor.:D
  3. woodywagon1965r
    woodywagon1965r
    talked to Randy at Cobra Valley about there tall valve covers ...make no mistake these are the coolest out there..check them out 399.00 for starts and up depending on how much polish you want rough cast would suit me fine ...
    ....I DONT WANT THEM.. LOL I NEED THEM
  4. 26 roadster
    26 roadster
    Garrett machine in OR make a really different sbf cover with a "Rampant Lion" logo, about $200.
  5. smallblock 302
    smallblock 302
    What kind of paint did you use?
  6. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    I found this pair at a swap meet for $25.00.
  7. Francisco Plumbero
    Francisco Plumbero
    from il.
    Will any of these clear a set of roller rockers? They all look a bit short. I like the idea the guy had about the Packard script letters, you could find cool lettering add it and paint it in.
  8. '46SuperDeluxe
    '46SuperDeluxe
    from Clovis, CA
    Sure look cool though! Credit this image to Rod & Custom Magazine.
  9. Ford-Man
    Ford-Man
    Cal Customs with cast aluminum spacers from Lane to clear the roller rockers. I still love Django's valve covers...very neat.
  10. 665.0coupe
    665.0coupe
    from Salina, KS
  11. 26 roadster
    26 roadster
  12. ***Area-51***
    ***Area-51***
    from Ohio
    vintage Edelbrocks
  13. propwash
    propwash
    from Las Vegas
    sbf v/covers don't come much cooler than this:
  14. 296 V8
    296 V8
    from Nor~Cal
    I want that .... cool
  15. kippers 34
    kippers 34
    Cal Custom polished and powder coated.[​IMG]
  16. willowbilly3
    willowbilly3
    from Sturgis
    I like the Cal Custom or Edelbrock cl***ics. I have been looking for some with no fillers or vent holes and the only ones I've found are the Edelbrocks but I'm too cheap to pop for a new set. I have a set of early Cal Custom sbc valve covers that are the exact look I want so I am thinking about plasing out a set of adapters. Then I can also run Chevy script sbc covers and mess with people's heads
  17. Drive Em
    Drive Em
    It is a common problem, once you modify something, you have to change something else. In this case, I installed a set of roller rockers on a 351 W, and the stock height valve covers would no longer clear. A set of aftermarket valve covers would do the job easily but nothing really caught my eye. The engine is going in a '64 Falcon wagon I am building, and I wanted the understated factory look of a black painted block and heads with red valve covers and air filter, so aluminum or aftermarket was out of the question. I toyed with the idea of valve cover spacers, but they are not cheap, and they require another set of gaskets that would complicate things. I like simple cheap hings so I went another route. I had an old pair of Moroso SBF steel chrome valve covers from my circle track days, and they would clear the roller rockers and poly locks. I did not like the Moroso logo, so that had to go. My plan was to cut out the Power By Ford letters from an old set of 351C valve covers and weld the piece into the Moroso valve covers so I would have a factory look (sort of) and still clear the rockers.
    The same process could be used for any set of valve covers on any kind of engine.
    The stock 351 W valve covers would not clear the Crane roller rockers I was using:
    The tall Moroso steel valve covers would clear nicely:
    The logo was going to have to go:
    The Power By Ford logo from a set of 351 C valve covers would look nice, so an 11" x 2 1/8" piece was marked out with masking tape:
    A 4 1/2" angle grinder with a cut off wheel was used to cut the piece out:
    The piece was de-burred and set aside:
    The Moroso valve cover was also cut out with the same dimensions 11" x 2 1/8":
    A little fine tuning with some tin snips made the piece fit exactly:
    The piece would be **** welded in, so the fit has to be pretty close:
    A couple of magnets hold the piece in place:
    The piece is tack welded in place:
    More tack welds are added about an inch apart alternating sides to prevent warping:
    Tack welds are added from side to side until the piece is completely wleded in place. A wet rag is run over the piece to keep everything cool as each tack weld is added:
    The finished piece doesn't look too good yet:
    The welds are dressed using a 36 grit sanding disc. Let the grinding disc do the work, and do not dig into the metal:
    The valve cover after grinding looks really nice and smoth with only a few scratches that will need to be filled with catalyzed glazing putty:
    The top of the valve covers will be primed and painted about an inch from the top while leaving the bottom part chrome for a different look.
  18. Drive Em
    Drive Em
    I finished them up:
    The valve cover was primered with a high build polyester primer to fill in the remaining scratches. I masked about an inch down from the top to keep the chrome that was already there. It was then sanded with 400 grit sandpaper:
    Duplicolor Fire Red was chosen as a not so bright red for the valve cover. The engine is going in a '64 Falcon wagon, and the factory colors would have been a black block and heads with red valve covers and air cleaner, which is the look I am going after:
    After the masking tape was pulled and any overspray wiped off, the valve cover was bolted to the engine:
    The finished valve cover will keep people scratching their heads trying to figure out where they came from. Now to do the other valve cover..............
  19. brekteffect
    brekteffect
    What about the stock late 80's mustang aluminum valve covers? There neat looking and you can get them for next to nothing on ebay, and they clear roller rockers.
  20. Those are really trick!
  21. I was thinking of those too.
    The hollow letter Cobra are my faves.
    The Cal Custom are really sweet too.
  22. AAFD
    AAFD
    from US of A
  23. Deuces
    Deuces
    I got a few pairs of those laying around in my garage from my 5.0 days.... Also a pair that say "POWERED BY FORD" from a '83.5 T-Top GT that I just sold not long ago.. Those should clear the roller rockers also...
  24. Gosh- don't you guys know mentioning any of this on the HAMB is like watching "American Pickers" and now the price is gonna go WAY UP??!! ;)
    Seriously- I am looking for a set of those for my OT 87 Mustang... if you ever wanna get rid of them. I'm just slightly west of you, in Canton.
    The spliced together ones look great also... and I really dig the FE adapter! That's a great way to get my buddy's Capri the "Mercury" ones he's been eyeballing..
    JK
  25. MUNCIE
    MUNCIE
    from Houston
    Looking ofr a aset of valve covers if anyone happens to have a set of finned or some weiand's send me a pm.I have been looking on e-bay as well as other places,thought it wouldn't hurt to try here as well.
    Thanks,
    Muncie
  26. MUNCIE
    MUNCIE
    from Houston
    Hoping someone has a set of sbf weiand valve covers....
  27. Muttley
    Muttley
    There really arent that many choices. I had a set of Cal Customs but they really didnt fit the style of my Comet, I traded them off for a set of M/T's that look much better IMO.
  28. willowbilly3
    willowbilly3
    from Sturgis
    There is a parts wanted section in the cl***ifieds, you might have better luck there.
  29. chuckles0
    chuckles0
    Here are my Keystones...chrome peeled and copper showing..lots of patina
  30. retiredblue
    retiredblue
    from california
    I know this is an old thread but I couldn't resist- I am pretty proud of them
